classifieds |
membership |
rennlist |
photo album     sponsors | upload photo | chat | marketplace     |
| Register | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | My Recent Topics | Vendor Directory |
Thread Tools |
#1 |
Rennlist Member Join Date: Oct 2009
My C4 shopping saga continues, hopefully more happily. Here's what I've got a deposit down on and a PPI scheduled for:
http://www.landmarkmotors.com/invent...rent=1&size=20 Not a lot of factory options but I like that FabSpeed exhaust. Price is right. And it's got a great service history. How scary is the branded title for the odometer fix; seems like not a big deal because fully documented, yes?Cheers, Liz |
#2 |
Rennlist Member Join Date: Oct 2005
consider a Rennfax before investing in a PPI if you haven't driven the car yourself. any nearby volunteers?
#3 |
Rennlist Member Join Date: Apr 2003
Even if you're comfortable with the documentation provided on the speedo change, it may be difficult for you to resell. (if you ever do) I'll let someone in the car biz speak to how much the title impacts the value.
At 62k miles (or is that 68k?) there should have been a recent 60k service done if it truly was well maintained. FYI on the 18" wheels... have them check to see if the proper steering rack brace was added. http://www.pcarworkshop.com/images/5...996_640496.pdf |
#4 |
Rennlist Member Join Date: Oct 2007
That's a good looking 993! Yes, it's a better price. That place always has good cars, but I don't have any experience with them. Not to long ago they had another silver C4 that a Rennlister was looking at.
If you are serious I know a couple of good local shops for a PPI, & I might be able to go & check it out for you. |
#5 | |
Rennlist Member Join Date: May 2007
Quote:
Interplast.Org "Healing Bodies, Changing Lives" |
#6 |
Guru
Lifetime Rennlist Member Rennlist Small Business Sponsor Join Date: Aug 2001
I would ask for pictures of the lower drivers seat, seems as though its been left out of view. Just my paranoid self speaking
Is this a great place or what? Chris 97 993 twin http://www.swiftengineering.com/ Cool Video Latest FN News |
#7 |
Hey, I'd be quite glad for an in-person look-see, Stealth993.
I tried to get it in for a PPI with Johnny Walker (per a recommendation elsewhere on Rennlist) but he was booked thru next week. So I went with his top recommendation of Redmond European, where I talked at length with owner Monty about the 993 and the whole SAI thing. (Opinions seriously abound on this issue but it was nice to hear him validate Tony Callas & an SAI test....) The speedo shows ~55k so it's really got ~62k. Is a Porsche-documented speedometer fix really questionable? I'm not going into this expecting to resell it, but of course it's a possibility. Thanks for all your careful eyes! Cheers, Liz |
#8 |
Rennlist Member Join Date: Dec 2002
Looks nice Liz. I think it's just the photo's but check the rear tires and wheel sizes, something seems strange. That doesn’t appear to be a factory arm rest, that looks like a Bird one to me, which I do like. http://www.birdautomotive.com/993.htm Check out the parking brake handle, it seems like two different colors. Aftermarket CD changer? Does it have a jack, tool kit and spare tire compressor? The climate control unit appears to be sticking out a little, no biggie. Usually the 993’s will need a clutch around 60-70k miles so have that checked closely. Use my 993 check list and drive them nuts with good questions…hello to Monty for me.
TCallas |
#9 |
Rennlist Member Join Date: Jun 2005
A 60k tune is standard service however, uknowns can pop up. I spend $5k on my 60k tune. The "UNEXPECTED" are down at the bottom--not major things but it equates to cash out of pocket.
TO BE DONE (Note: * denotes parts supplied by me) 1. * Suspension upgrade: a. 4 X Bilstein HD shocks (with 30mm extra threads) b. 4 X ROW M030 Springs c. Front 22mm M030 Sway Bar d. Rear 20mm M030 Sway Bar e. Rear Drop Links f. Front Drop Links g. KLA Strut brace install 2. * Change spark plug wires-Beru 3. * Change air inject check valve (SAI check valve) 4. * Change both cabin air/pollen filters 5. * Change the engine air filter 6. * Change all 12 spark plugs (yea, esp. # 12 that, I know, is a PITA) 7. * Change both distributor caps 8. * Change both distributor rotors 9. * Change fuel filter 10. * Change engine oil (I will supply 10Q Mobil 1 - 15W50) 11. * Change large oil filter 12. * Change small oil filter 13. * Change A/C compressor drive belt 14. * Change Alternator drive belt (inner) 15. * Change Alternator drive belt (outer) 16. * Change power steering belt 17. * change ignation coil wire 18. Change manual transmission fluid. REDLINE 19. Bleed/flush the clutch hydraulic system 20. Bleed the brakes Note The brake system was completely flushed less than 7 months ago so the (ATE super blue) 21. Please perform all the (remaining) normal checks, lubrications etc. as specified in the 60k service interval. In particular, please re-lubricate/check tolerances of the manual transmission gear-shift linkages/bushings etc. 22. Remove and Clean ISV 23. Replace front hood shocks **THE UNEXPECTED** -belt tension indicator-bearing was froze. -Ignition coil-shot for the most part -Distributor rebuild
95 C4 993 Black/Black, 68,900 miles (officially double the miles in 7 years of ownership) LWF, ECU upgrade (Rennsport) Mille Miglia exhaust, XM, Fabspeed Air Box, BMC Filter, white gauges, silver emergency brake and shifter, ROW MO30's, Bilstein HD's, sway bars, KLA strut bar, Gert Protection Bar 77 Ford Bronco Sport-Light Jade, 351, 3" Lift, 32"s, 45,000 miles, ORIGINAL CLASSIC 05 Navigator, white, khaki interior--great SUV 07 Madza CX7-silver and gray |
#10 |
The only odd thing I see on your list is that I have personally never seen a faulty or even weak 993 Ignition coil. There are two ignition coils (as one unit) on the 993. Tony Callas
TCallas |
#11 | |
Quote:
You can't go wrong with Monty!! He is the one who found me my C4. He worked on it for the last 10 years. He also owned like 10 911, all aircooled, but no 993's. I don't see why the speedo is a issue if you have the documentation on it. They break, & get replaced all the time. |
#12 |
Gaaaah! Sale canceled; husband decided he couldn't live with the odometer replacement. Back to the drawing board. And wouldn't you know, Titleist decided to store his C4 and won't be selling it until spring which is too late for me as I'd like to be able to compete the full SCCA autox season.
OK, 3's the charm, right? Where's my C4...? Cheers, Liz |
#13 |
Rennlist Member Join Date: Mar 2009
How extensive are the records? An odometer replacement would give me great pause, but if you have a separate service invoice during the time prior to the swap showing <6K miles, and the swap was done at the dealership and documented well (as the ad states,) then I wouldn't worry about it.
'95 993 C2 [Polar/Black] ... |
#14 |
Rennlist Member Join Date: Jun 2002
Liz:
I am pretty sure I called about that car back in the spring. Did they tell you the owner has several Pcars and is looking to get a GT2/GT3? I went elsewhere due tp the odometer discrepancies- that and the price was too high. Cheers, Paul.
'96 Carrera 4 Coupe '04 Mini Cooper S '04 Land Rover Discovery SE7 |
#15 | |
Quote:
| Thread Tools | |
