oill leak pictures included
I have the new gaskets and bolts ready.
I was able to loosen ALL of the bolts without much problem.
I'm just alittle nervious about the level of torque to put on the new bolts.
I'm afraid I will tighten them to tight.
Not enough room for a torque wrench.
Kevin
Kevin
I had the same concern. I figured I could always tighten them more, so I was careful not to over tighten. After I had it all together, I wiped everything clean and went for a drive. I found both sides leaked just a bit, so I gave them about another half turn. That did the trick, no more leaks.
Tighten with a regular allen key until you feel like you can twist it anymore, then a further 1/4 turn with an allen socket and bigger wrench, should give you around 7ft.lbs. (I measured that with an expensive torque wrench)
How many hours did you spend on the Valve Covers R&R? I too have bought the gasket set (Sunset) however didn't consider replacing the bolts. In retrospect replaceing the bolts is a good idea. TIA
Really,,, two hours of so if you recall. A local N. Atlanta shop is quoting 8 hours for the (edit: upper and lower) all valve cover gasket R&R - when hearing this I took a double take. The same shop is quoting 6 hours for an R&R of the ignition wires. And yes this for our 993 motor. Go figure.
I'm attempting to get the factory service times for these two procedures
EDIT: 6 hours for all valve cover R&R (upper & lower)
5 hours ignition wire set R&R (complete Beru dressed set)
Data per Porsche Cars North America 1/9/2010
Maybe it just seems like 2 hours at this point. :-) I had done the ignition wires and plugs previously, so the removal of the muffler on the passenger side was easier than if it had not been off before. Much of the other items had been off before too, so there wasn't much trouble getting to everything. I'm sure it wasn't 6 or 8 hour. I guess it could have been a little longer than that but certainly not 6 or even 8.
Really,,, two hours of so if you recall. A local N. Atlanta shop is quoting 8 hours for the valve cover gasket R&R - when hearing this I took a double take. The same shop is quoting 6 hours for an R&R of the ignition wires. And yes this for our 993 motor. Go figure.
8 hours for a Valve Cover gasket R&R is a ripoff. In my opinion you should find another mechanic.
Did the lowers on my 97 in September (OK, I'm a liar. I supplied beer and watched the guy who did them.) and took roughly 2 1/2 hours including removing mufflers. Looked fairly straightforward (says the guy who watched).
Thanks Kevin, et al ~ I did the spark plugs/distributor cap/rotor in the spring of '08 only to add the LMPP muffler modification because well,,, I’m here already why not. Agreed,,, take your time, clean things up as you mosey along attending to the heart of the 993. Time to dust off the factory 6 binder service set!
