993 Clutch Disk Specificiations?
Hi All,
Does anyone know what the correct 993 clutch specs are (trying to see if an alternative solution will work).
I believe its a 240mm disk (9.4")? (Outer Diamater)
23 splines
1" Spline Diameter
(Factory Contact Patch of the disk itself a is a 30.15mm), but you can go up to 40.17mm?
Does anyone know what the correct offset should be?
(I think Sachs list it as 23,3x26,3-23N)
23 splines
1" Spline Diameter
Hi Jay,
Why do you ask as replacement clutches are generally sold by application, not physical specification?
Andy
Andy
