993 Forum 1995-1998
Emergency Engine Lid Release
Old 07-25-2010, 05:55 PM
ozpilot
ozpilot's Avatar
Default Emergency Engine Lid Release
This morning I installed an emergency engine lid release behind the left rear tail light. Its more convenient to put it there instead of behind the wheel arch liner since I only need to remove one screw to get to it.
You will need some single thread steel wire, something to use as a handle (I used a plastic 'O' ring) and some wire ties.
First remove the left tail light. Now you look inside the housing ceiling near the center reflector. You should see a small rubber lining.
Push the steel wire around this lining and it will exit into the engine bay close to where the primary release tube is. Extend the wire along the tubing towards the release latch.
The release latch has two holes, one of which will already be taken by the primary release cable. Push the wire through the second hole (as shown below) and wind it back and tie it off to itself, making a loop.
Use the wire ties to secure the emergency wire to the primary tube (not too tight since the cable has to move).
Attach the handle to the end at the rear tail light, reinstall the light and your done!
p.s. I also attached a small fishing sinker to the end of the primary cable in case the screw on the latch ever lost its grip on the wire.
John
Old 07-25-2010, 06:04 PM
rsr91128
rsr91128's Avatar
Great job, this should be done on every 993 that didn't come with it, IMO.
I used the emergency cable from Porsche, part # 964 512 521 00, it was less than $10.00 and is the same as the front hood release loop cable. Hope I never have to use it!
Old 07-25-2010, 07:32 PM
IXLR8
IXLR8's Avatar
I'd hate to think how one would get the engine lid open without a back-up release.
This was my solution...
I got most components from a bicycle shop:
1 - bicycle brake cable.
1 - bicycle cable casing (in Speed Yellow) cut to length by user.
2 - bicycle stainless steel cable casing ends.
2 - rubber caps (optional).
4 - cable ties (in Speed Yellow).
Further info in my Engine Lid Back-Up Cable Release how-to.
Old 07-25-2010, 07:47 PM
Cactus
Noodle Jr.
Cactus's Avatar
I was just wondering today how to adjust this?
Old 07-25-2010, 07:55 PM
IXLR8
IXLR8's Avatar
Adjust what? Do you have too much free play in your OEM cable release?
Old 07-25-2010, 11:44 PM
Cactus
Noodle Jr.
Cactus's Avatar
Yes. Also I noticed my lid isn't closing normally and I have to slam it hard. I was driving around the other day with is unlatched.....
Old 07-25-2010, 11:47 PM
IXLR8
IXLR8's Avatar
You shouldn't have to.
Usually latches are adjustable. The lid and adjacent body panels should line up flush. Is your engine lid latch loose?
Old 08-14-2010, 05:28 PM
jdistefa
jdistefa's Avatar
You can adjust the latch and the cable tension. I also glued small mid-density rubber bumpers onto the rear deck lid to provide a little squish/tension/rebound.
Great writeup btw, thx... I'm going to do the same thing .
Quick Reply: Emergency Engine Lid Release
