993 Forum 1995-1998
993 steering rack dis-assembly.
Old 01-10-2011, 07:41 PM
bcaway
bcaway's Avatar
Default 993 steering rack dis-assembly.
Anyone pulled a 993 rack apart? I need any tips on dis-assembly.
An exploded view would be even more help.
I have a leaking seal (have seal kit from: http://www.klaindustries.net/)
I have removed the 3 bolts and removed the input shaft cover, exposing a bearing, whats the trick to removing the bearing?
Old 01-11-2011, 03:00 AM
Kiwi Carguy
Kiwi Carguy's Avatar
Sorry cant help with instructions but had the same happen in the last year. Had the work done at an Indy and the total cost was $1500. They sent it to a firm in Auckland who refurbished it. Just FYI
Old 01-11-2011, 03:28 AM
Mike J
Mike J's Avatar
Have not done this either...I pulled and installed the rack, but had it refurbished by a rebuilding company. I talked to them, sounded like some specialized tools are required, so I would be curious what you find out.
Can you take pictures of the process? It would be a great addition to pcarworkshop...
Cheers,
Mike
Old 01-11-2011, 03:59 AM
bcaway
bcaway's Avatar
Thanks Kiwi Car guy, the name of the Auckland outfit would be good to have, unlikely I will send it there as I can have it refurbished for around $450 USD. But I may get a tidbit of info on how it comes apart from them
It seems really simple (famous last words) with only a set of o rings and a couple cup seals. Appears to be basic hydrolics and I've rebuild rams before. We don't have any Porsche mechanics in town. So I'm DIY on this one.
Apart for a tool I may have to make to remove the bearing the unit looks simple with a couple c-clips in each end and a pin thru the input shaft.
I will definitely document the rebuild with photos etc. and share. But before I go experimenting and break something on disassembly I'm hoping to talk to someone that has rebuilt one just to get the low down of order of disasembly.
Old 01-11-2011, 02:02 PM
Michaelc
Michaelc's Avatar
I picked up a rebuilt ZF rack on Ebay, from carsteering.com for around $350 = core. Nice rack!
Old 01-13-2011, 05:00 AM
bcaway
bcaway's Avatar
bump... anyone know someone that has rebuilt a 993 rack, I need 5 mins of his time to discuss the disassembly order.
cheers
Old 01-13-2011, 09:47 AM
Garth S
Garth S's Avatar
Here's a well documented thread on a 928 rack rebuild ....... worth reading, for it is quite similar to a 993 rack.
Post your results please, as I've a leaking 993 rack in the spares pile .... and am masochistic enough to attempt a rebuild: good luck
Quick Reply: 993 steering rack dis-assembly.
