993 Forum 1995-1998
Sponsored by: DashLynx
8 way seats...only working 4 ways?
Old 04-03-2011, 01:00 PM
Safemoney
Safemoney's Avatar
Default 8 way seats...only working 4 ways?
Anyone have any suggestions or experience with this problem?
The passenger's side seat - it has 2 (typically 4 way) buttons to move the seat. The there are two arrows on them that point up and down on each button. Those directions actually work on the buttons, but the front and back directions don't.
It just happened all of a sudden, but I'm confused because some of the power works and some doesn't.
Help!
Old 04-03-2011, 03:30 PM
Black993
Black993's Avatar
Check the fuses up front in the box (thought not sure why only parts of the power would work) and check the connections under the seat.
Old 05-14-2011, 11:16 PM
craig001
craig001's Avatar
It is fuses 4 & 6 IIRC - 30 amp. But check p-car online and look for the switch rebuild DIY for more info. I wanna say that power just flows down the connector to all the pins.
Old 05-15-2011, 12:21 AM
SKM
SKM's Avatar
Default May be the cable
It may be the cable from the motor to the seat/track. The end(s) usually strip-out if the seat is stuck at the fore- or aft-most position. Cable is $60 and a minor PITA to replace. Look under thr seat on the side closeest to the door and determine if the cable from the motor in front center is securely seated in the front at the motor and the rear at the track.
Old 05-15-2011, 12:28 AM
nile13
nile13's Avatar
My guess is that switch might be bad. But let's troubleshoot one things at a time. How many arrows are on each switch? 4? How many switches per seat? 2? If so, are both switches behaving the same way?
Old 05-15-2011, 03:23 AM
briefescape
briefescape's Avatar
I have two extra 4 way switches with cables if you need . It is a common thing .
here is DIY repair first
https://rennlist.com/forums/964-foru...lace-them.html
Cheers Guy
Old 05-15-2011, 03:29 AM
briefescape
Btw switches are anywhere from $130 to $150 each on Pelican Parts and other sites .
Cheers Guy
Old 05-15-2011, 04:04 AM
911PERVY
911PERVY's Avatar
Check the spade connectors on the motors havent snapped off. Try blowing some air behind the switches as they do crud up
Old 05-15-2011, 05:12 AM
got*ki
got*ki's Avatar
+1 on the cables. If you hear the initial engagement of the motor then nothing else, it could very well be the cables.. Almost like a silent click then no movement...
Old 05-15-2011, 08:19 AM
Rialas
Rialas's Avatar
Sit on your seat and rock up and down backwards and forwards whilst pressing the button. They tend to stick at their extremity of adjustment. My car was like that a year ago when I bought it and has been fine since. Quite a common problem.
Old 05-15-2011, 10:54 PM
craig001
craig001's Avatar
If you need the cable shafts try dC Automotive - 235mm (front/rear) are $20 each. They also have the 265mm shafts avaialble. I picked up some seats with more power adjustments for the 96 and the seller failed to mention that one of the adjuster shafts on hte passenger seat was stripped, sigh. ONly problem was that I had to order more stuff to get my order to $75. As you can imagine, it was not hard to do, LOL.
Old 05-16-2011, 12:10 AM
David in LA
David in LA's Avatar
The switches have a tendency to fail (these cars are over 15 years old!) with age...when the switches on my white cab went, once I found out what Porsche sold new switches for, I cannibalized the switches from a damaged pair of seats that were laying around.
Old 05-16-2011, 02:24 AM
MDamen
MDamen's Avatar
Mine had similar issues. No noises at all when I used some of the switches. I followed the DIY for cleaning the switches and now the seat works properly.
Old 05-16-2011, 06:22 AM
ericthepilot
ericthepilot's Avatar
Mine failed on the passenger side. Some of them. It also has heated seats and I haven't tried those yet. Too hot already in Florida. But I do want them to work. Is That a switch failure to probably if the heating doesn't work ?
Quick Reply: 8 way seats...only working 4 ways?
