993 Forum 1995-1998
Sponsored by: DashLynx
Caster Eccentric...explain please
Old 04-22-2011, 05:57 PM
kjr914
kjr914's Avatar
Quad,
If you truly wave the white flag, you can take it to a shop with a press... I'm going to be doing this soon and am really curious about how much fun/torture this will be.
Old 04-22-2011, 07:31 PM
AOW162435
Seared
AOW162435's Avatar
Originally Posted by Quadcammer
stupid shells just don't want to come out. I've pretty much given up.
PM me if you want the arms completely refreshed - old bushings removed, arms bead blasted, new bushings installed, sent back to you.
Andreas
Old 04-22-2011, 07:34 PM
cp993C2S
cp993C2S's Avatar
Don't worry about the 12mm...the caster bolt will not rotate when you remove the nut. Mark it against the forging before removing then hold it in-place w/ a channel-lock and re-torque the nut.
I didn't even try to change the bushings myself...Chris Walrod did an outstanding job...thanks again, Chris!
Car is awesome with this + PSS10's...do it.
Old 04-22-2011, 08:27 PM
Cincy_Ron
Cincy_Ron's Avatar
yes I am doing the bushing mod.
got the control arm out a few hours ago, but these rear bushing shells are being very insolent.
I had mine pressed out and the arms bead blasted at a local machine shop. I think I paid $75 for it. Didn't feel like dealing with hack saw, propane torch, etc.
Old 04-22-2011, 08:32 PM
Quadcammer
Quadcammer's Avatar
Received 1,373 Likes on 794 Posts
Andreas
Sounds lovely.
You going to hershey. I could just give them to you then?
thanks!
Old 04-23-2011, 05:54 PM
e9stibi
e9stibi's Avatar
Yeah, i do, thanks Darin.
Do not give up. I know exactly where you are because I was quite inefficient on the first arm and applied my learnings to the second side which was very easy compared to the first side:
If the big sleeve does not come out easily, you need to make the saw cuts deeper. Just do two cuts 1/4 inch apart and you can chisel it out. ("open like a fish can"). Take your time to make the two cuts and it pays off BIG when you change tools.
Old 04-25-2011, 10:42 PM
Quadcammer
Quadcammer's Avatar
ended up taking them to a friends dad with a shop.
shells out, lcas beadblasted, and hats wire wheeled.
what does this tell me?
I need more bloody tools lol
Old 04-26-2011, 01:27 AM
uicnick
uicnick's Avatar
how did your old bushings look? have you gotten her on the road yet? notice any improvements?
Old 04-26-2011, 10:22 AM
Quadcammer
Quadcammer's Avatar
They generally looked ok, although there was some localized cracking. Then again its really hard to tell by just looking at them.
I didn't have time to get the new ones pressed in yet, but I'm doing that tonight, and I should have it back on the road by wednesday, and I'll post an update.
Looking forward to this as I had some tramlining and slight vibrations.
Old 04-26-2011, 10:54 PM
Quadcammer
Quadcammer's Avatar
ok bushings went in like cake with a vice.
One LCA is on the car. Little bit of a bitch getting that rear bushing in as its quite tight. I used a jack to get it in place, but fine tuning it to get the bolt in took a bit of light tapping. A tip that worked for me was to tilt the control arm almost vertical as it made it easier to adjust the axial location.
Quick Reply: Caster Eccentric...explain please
