993 Forum 1995-1998
Sponsored by: DashLynx
993 Long Term Storage
Old 06-27-2011, 06:57 PM
ppashley
ppashley's Avatar
Default 993 Long Term Storage
I am putting the car into multi-year storage.
Since there is much talk but limited data on this, I'll monitor the car over the next few years, and update on status.
I am expecting some work will be required on the car in time, and I'll track that here.
The car will be serviced approx annually, but will not see use, as I will be overseas. The car is a 1995 993 with 42k miles.
Update 1: June 25th 2011
- Car put in Storage
- Tyres filled to 50psi
- Sta-bil added to fuel
- Car put away after a hot run
- Car cover
- C-TEK charger
I'll add another update in 6-12 months.
Old 06-28-2011, 01:28 PM
AOW162435
Seared
AOW162435's Avatar
My junker has been on jack stands since January. I know the feeling...
Andreas
Old 06-28-2011, 02:29 PM
No HTwo O
No HTwo O's Avatar
Tires should be closer to 58 PSI, IIRC. Use nitrogen, if you can get it (dryer air).
Park on a thick mil plastic painter's tarp. You should also consider putting several pounds of desiccant in the cabin.
Fresh oil? I hope.
What are you going to monitor? What data are you planning to collect? For example, use oil analysis during the storage period my be intersting to see.
Old 06-28-2011, 05:17 PM
ppashley
ppashley's Avatar
Andreas - the dung beetle still in hibernation? Seems a bit long?
NoHTwo0 - Yes, Fresh Oil - engine and gearbox (tranny). Fresh brake fluid.
Intention is to monitor general issues, and track maintenance etc.
Oil analysis would be interesting, but since I'll be out of country, not easily possible.
Old 07-02-2011, 11:21 PM
Psoncanada
2nd Gear
Psoncanada's Avatar
I would put it on Styrofoam as well - 1-2" thick - to further help the tires stay round.... And some steel wool in the exhaust pipes...
Old 07-03-2011, 11:45 AM
95_993
95_993's Avatar
For storage, I use tinfoil wrapped with a rubber band over exhaust tips & air inlets to heater boxes underneath. Keeps the critters out and is really easy to remove.
+1 Especially if it's sitting on a typical concrete garage floor
Lastly, I would treat the leather with something like LeatherMasters Vital. A little 303 protectant on the door/rubber seals wouldn't hurt either.
Old 07-03-2011, 02:14 PM
paa502
paa502's Avatar
Doors on first "click", helps to restore shape of the rubber seals.
Old 07-22-2012, 11:58 AM
ppashley
ppashley's Avatar
Default 993 Long Term Storage (Year 1 Update)
So its just over 1 year now that the car has been in storage.
Next week, will be returning to Europe and will check on the status of the car.
Intention is to remove the DME, and turn the engine over a few times to get the oil pressure up, then replace DME and start.
Any other tips, other than checking for rodents etc.
Phil
- Car cover
- C-TEK charger
Update 2: July 2012
- Will confirm next week!
Old 07-22-2012, 12:06 PM
77'3.6vram
77'3.6vram's Avatar
I would not worry about the tire pressure as you are going to need to replace the tires anyway after 5+ years in storage.
Old 07-22-2012, 12:07 PM
RocketJohn
RocketJohn's Avatar
Interesting thread...
Old 07-22-2012, 06:00 PM
NC TRACKRAT
NC TRACKRAT's Avatar
IMHO, using double-dose STABIL in the fuel will be sufficient for 2 yrs. at best. At next visit, if at all possible, I would drain tank and re-fill with fresh fuel and double-dose STABIL. Anyone got an easy method of draining a 993 gas tank? Next to impossible going in the filler neck to siphon.
Old 07-23-2012, 10:27 AM
Christian J
Christian J's Avatar
An easy way to drain the tank involves removing the tank guage. With a flexible hose you can get almost all of the fuel.
If you have non-ethanol gas I wouldn't worry about the fuel if it's going to be 3-5 years. I also wouldn't start the car annually. It introduces condensation and acids produced from combustion into your fresh oil and for what benefit? Fog the cylinders with oil, cover the inlets and exhausts as suggested above and let it sit. I've stored motorcycle engines for years with no damage using this method.
I agree that the tires will be suitable only for a drive to the tire store after 5 years so no need to worry about them either.
Corrosion is your major enemy. Maybe push the pads back into the calipers?
Old 07-23-2012, 10:50 AM
Quadcammer
Quadcammer's Avatar
Received 1,372 Likes on 794 Posts
would pulling the hose to the fuel pump not get the job done?
Old 07-23-2012, 03:40 PM
Robert993TT
Robert993TT's Avatar
About fuel and longtime storage over a few years without starting the car. I think I would put Aspen fuel in the tank. It do not change during longtime storage as regular pump fuel does. If the longtime storage is just over the winter month I think regular pump fuel is just fine. I have not had any problems ever. The pump fuel in my Ducati is just over 12 months old right now, but I will fill it up with new fuel before the winter storage. I always fill it up with ethanol free fuel.
http://www.aspen.se/Aspen_(eng)/Consumer/Products
Old 07-23-2012, 04:01 PM
Van1
Van1's Avatar
I'd check for evidence of rodents inside of your cooling fan area. When i first bought my 993, there was evidence that rodents had lived in the engine bay at one time as a large portion of the sound pad was gone and one of the ground wires was chewed. While removing my cooling fan to install an RS pulley while my engine was out I had discovered where all the sound pad went. It was all over the top of the engine underneath the cooling shroud.
Quick Reply: 993 Long Term Storage
