993 Forum 1995-1998
Sponsored by: DashLynx
Pesky sunroof!!!
Old 07-13-2011, 01:53 PM
ginch
ginch's Avatar
Default Pesky sunroof!!!
So I jump in my car this morning to drive to work. Cars in the garage and its raining like crazy outside. The sunroof was open from the day before so I hit the switch to close it and nothing. No movement.No noise. Nothing!!! Fiddled around with the button for a minute or so and it finally closed. What are your thoughts? Faulty switch? Sunroof motor on its way out? Any help would be appreciated!
Derek
Old 07-13-2011, 02:41 PM
kjr914
kjr914's Avatar
Just know you are not alone... Mine decided yesterday it doesn't want to close all the way w/o some manual persuasion. I know what I'm doing this weekend...
Old 07-13-2011, 02:42 PM
ilko
Agent Orange
ilko's Avatar
Weld it shut!
Old 07-13-2011, 03:42 PM
VNTGSPD
VNTGSPD's Avatar
Behind the zipper in the rear headliner is the electrical plug that goes to the motor. The contacts get corroded and causes the condition you experience. I had this same problem 4-5 years ago, cleaned the contacts, and it's worked perfectly since then. I use mine every day.
Ironically, my wind deflector bracket broke on my way to work this morning. Rough day for sunroofs!
Old 07-13-2011, 04:12 PM
skl2
skl2's Avatar
Document your work!! There isn't enough good DIY info on sunroof repairs. Im mortified to even try and remove the trim off the bottom of the sunroof - makes a rottle noise at highway speed in the rear passenger corner. If I push on the roof or on the trim it goes away..probably just need to tighten it but I dont want to screw anything else up by removing and reinstalling!
Old 07-13-2011, 08:24 PM
ginch
ginch's Avatar
Thank you for the replies!
Old 07-13-2011, 09:46 PM
Vorsicht
Vorsicht's Avatar
I've had a similar problem. In my case the "open" direction worked fine but the "close" wouldn't work. You may find a similar thing as time goes on and generally it will worsen.
If so you can replace the switch easily. Or do what I did which was to remove the switch, carefully take it apart and clean the contacts in the switch with a Q-tip. It worked fine for me.
Good luck and let us know what happens!
Old 07-13-2011, 10:42 PM
User 122821
User 122821's Avatar
The front tabs on each side which are made of thin plastic and break. This jams the sunroof sliders preventing movement. I've replaced them on both of our 993s.
Old 07-17-2011, 07:02 PM
mongrelcat
mongrelcat's Avatar
Had the exact same symptoms, new switch solved it. Rapid, repeated toggling of the faulty switch may work in a pinch
Old 07-17-2011, 08:36 PM
ginch
ginch's Avatar
Well its been a week and I haven't had a problem since. I'm sure if its happened before its bound to happen again but until it happens more frequently, i'll just keep my fingers crossed!
Old 07-17-2011, 10:12 PM
jakfrost
jakfrost's Avatar
Like my daughter does when her car starts making a 'funny noise'...she just turns up the volume...problem solved, hahahahaha.
Jim
Quick Reply: Pesky sunroof!!!
