is this oil leak bad?
Had a PPI done today and took these pics. Shop says oil leak is common on these cars as always and the severity of the leaks is actually not bad 8/10 10 being best. The only concern is the transmission leak which is not common. What do you think? Any other problems your trained eyes can see? The engine only have 37k miles btw. Thanks.
Not bad at all. You need new plug wires and that is one of the worst jobs I've ever done. The leak at the chain cover is nothing to worry about. Snug the bolts a little and keep an eye on it. Might as well do plugs, plug wires and lower valve cover gaskets all at the same time. This is a solid full day in the garage if you DIY it all.
No wonder power is missing a little, maybe its misfiring or not firing at all?
You should thoroughly degrease your engine (engine compartment and underside) as well as the transmission in order to determine what the rate is of the leak. Its a messy job, but someone has to do it.
If that ignition wire is broken, you definitely need a new set of wires. But don't worry, you do not need to spend some $450 for a complete set; you can just replace all 14 wires themselves for $135 because the spark plug caps and suppression caps don't age. Mine were still like new; the rubber was as pliable as the day they came off the production line as can be seen in the following pic with my replacement Beru Silicone Copper Cables...
As for the valve cover leaks, all you need are a new set of valve cover seals. I replaced them on all 4 valve covers; they are bone dry! There is talk that the OEM Porsche valve covers warp and that you need billet aluminium valve covers to stop all leaks...I highly doubt the OEM covers leak and I've never been responded to when I ask by how much they warped.
But having the OEM plastic covers where you might have breaks in the ignition cable is a plus; there is far less chance of a misfire as compared to using billet aluminum valve covers.
In any case, those wires are shot if that is a break.
