Best Scantool for 97/98 993?
http://www.durametric.com/default.aspx
If you are just looking for the readiness flags and to check the codes on check engine lights and clear codes to turn off the check engine light, there are a number of them out there. I have a Actron CP9180.
I looked into the Durametric. Great unit. But you have to hook it up to your lap top to use it. For some it is the way to go. I just don't think I would use all of its features.
We use the Durametric at the shop. It is nice but works better on the newer cars. It is a bit limited on the 993.
For a quick read, reset of the error/readiness codes we also have an Actron. They are inexpensive and can be found at most auto part stores.
Sounds like you want the Durametric. I believe you can put three Porsches VINs into it.
Agent Orange
I have one of these: http://cgi.ebay.com/ebaymotors/U380-...motiveQ5fTools
It's a little over $20 and reads and clears codes. It's all I ever needed for the 993.
1pcarnut,
It's my impression that Durametric are pretty good to work with. It would not surprise me if they would "enable" you to use a unit on more cars, once you hit the limit, as long as you weren't a professional trying to get around buying the professional version. This would certainly be worth asking before you purchase.
1pcarnut,
http://www.durametric.com/buyus.aspx
Durametric is a bit pricey for me. Another i've seen mentioned multiple times and I'll probably get if nothing better shows up is the equus/innova 3030 (not exactly sure of which model, 3030/3020/3100....need to do the research again...)
My biggest complaint with the Durametric software is that there's currently no active drive link for brake bleeding, which is necessary for the C4/C4S/Turbo cars. It looks great otherwise. Too bad there just aren't that many monitored systems on the 993 compared to the later cars.
I have the Durametric which I find great however its doesn't clear the airbag light even though it is supposed to, so be aware of that or at least ask. It has way more functions than I have used though and as others have said a simple handheld tool may do all you need.
Agent Orange
After this thread I emailed Durametric as I always meant to. Here is their response below.
On Aug 9, 2011, at 9:34 PM, James wrote:
Hi there,
Has the 993 been added to Version 6 yet?
Also my Durametric software/cable works great but will not clear the airbag light which I mainly why I purchased it. Why is it doing this? It is not a faulty module or connection etc as my dealer/independent has no problem clearing it with the Porsche Scan tool? The Durametric website clearly states that it clears it on my model car which is a 1996 Varioram 993. Any ideas or help?
Hi James,
Thank you for writing. Yes, version 6 now includes support for the 993. You can install the program from our website: www.durametric.com/downloadv6.aspx. Though for the most part version 5 worked very well on the 993, we encountered some intermittent issues with the communication with the airbag units in those cars. Those issues have been corrected in version 6.
Let us know if you have any further questions.
Owen Sutton
Diagnose Technic
888-854-5523
Hi there,
Hi James,
Owen Sutton
Diagnose Technic
888-854-5523
