ignition cables
ignition cables
993 carrera S 1997 tiptronic WP0AA2999VS322775
Help me please to find a full set of 12 new ignition cables...
Whoever you buy from, I'd strongly suggest that you buy the fully assembled set that includes all grommets, clamps, boots, etc. They are slightly more expensive but worth every penny when you go to install them!
I think the 993 ignition wire set is by far the most complicated I have ever seen! I thought $450 was a bit steep for them. But when I saw them I realized how much goes into manufacturing them and then thought the price was actually reasonable. I must be buying too many Porsche parts resulting in my sense of reality being warped!
RL Technical Advisor
Same here since my connectors looked like new and I mean like new after cleaning them up. The Beru spark plug connectors and suppressors are first rate in quality. They all ohmed out in-spec as well.
I made my own wire set using Beru Silicone Copper wire and Beru M3 terminals which were crimped using a Beru crimper. This way I had control over the quality (no nicked wires, insulation cut square using a jig I made).
I've even sold 5 sets of wires so far.
I'm not so bright sometimes. I'm sure you can enlighten me.
But you have the vendor part correct. Sponsoring vendor
We've beat "why not" to death... resistors fail, etc. Yawn.
