removing rear suspension
#63
There is a show on Netflix called "obsessed", so I know about this stuff.
Your cool as long as you don't have to take it apart and put it together three times with your right wrist tucked tightly to your chest.
The parts on the drive way laid out like that however is not a good sign.
Nuts bolts etc. is fine for reference, but obvious parts like this seem to indicate you need professional help.
P.S. the two mufflers on the same side are causing me stress, not to mention the one rotor.
#66
jackal, you're website is absolutely great. One of my first 993 finds before ending up here on RL. Thank you for your effort. You seem like your having a great time and it shows in your work. Cheers bro!
#69
fitting new gaskets and screw seals to the chain box covers
oil the backside of the gasket
slot it in
loctite 574
plated screws and new rubber seals for the 8 lower screws
torque them up carefully 9nm
all done
#72
Well done!
#74
Seared
Some people wander to the edge, and then casually slide down the slope.
You, sir, strode vigorously to the edge and then took a swan dive off the Cliffs of Dover....
Great work!
Andreas
Great work!
Andreas
#75
I was going to blast and repaint the chain box covers and also clean up and then lacquer the ali valve covers but I decided that the project was bloating too much so anything more to do with the engine will get done when it comes out next year. I will degrease and completely clean all teh crankcase then and the gearbox.
