993 Forum 1995-1998
Recap of the SAI circuit
Old 10-25-2016, 06:19 PM
  #616
nine9six
nine9six's Avatar
Originally Posted by william_b_noble
I just don't understand the need to insult people who are trying to be helpful. I no longer have my 993, it was stolen. I was trying to offer my knowledge of a car I knew very well. I am very sorry you have been offended. I will unfollow this thread, clearly you know enough to satisfy everyone and YOU at least do not want nor value the input of anyone else. This is not my loss, but disparaging the knowledge and opinion of others is not helpful.
Enjoy your car. No need to reply.
William,
My most heartfelt apologies, as my post was not intended to insult.
I have found that most people outside of design, development, and test engineering, do not have an intimate working knowledge of the terms most commonly associated with Root Cause/Corrective Action.
Again, please accept my apologies. So sorry to hear your 993 was stolen!
Old 03-02-2017, 12:46 AM
  #617
eloyex
eloyex's Avatar
Old 05-19-2017, 11:29 AM
  #618
PasPar2
PasPar2's Avatar
can someone please post the latest circuit pic? the links are no longer valid.
thanks
Old 03-10-2018, 01:39 PM
  #619
ekimerpud
ekimerpud's Avatar
Looking to buy one of these. Will pay top dollar. Please PM me.
Mike
Old 03-16-2018, 05:01 PM
  #620
PRSWILL
PRSWILL's Avatar
So I did the clean out last fall. New check valve, and all ports clean as a whistle with clear fluid running out of all of them. get in the car and the CEL comes on after 50 miles! Is this an O2 sensor? My engine is super clean- all of the valves were spotless- you can still see ceramic on all of the seats. the car doesn't burn oil or blow any smoke ever. All I can think is one of the 4 O2 sensors is bad. Any other thoughts?
Old 03-19-2018, 08:54 AM
  #621
Jay777
Jay777's Avatar
Mike
Or give this a try:Legal SAI work-around
Old 09-24-2018, 08:32 AM
  #622
Teddy2
Teddy2's Avatar
Have one of the testers purchased from the developer - never used - PM me if anyone is interested
Old 09-24-2018, 08:36 AM
  #623
Teddy2
Teddy2's Avatar
By pass circuit kit "SAI" from early on in this thread - never used - for sale
Old 09-24-2018, 05:35 PM
  #624
jimbo3
jimbo3's Avatar
PM sent.
Old 09-26-2018, 11:30 AM
  #625
PRSWILL
PRSWILL's Avatar
There's been a couple threads on this- I found a small vacuum line unplugged by the SAI valve and the code stopped firing when I hooked it back up.
Old 09-29-2018, 02:52 PM
  #626
pp000830
pp000830's Avatar
Received 1,459 Likes on 1,029 Posts
Default Replace the check valve first:
The first and lowest cost thing to do is to replace the secondary air injection check valve. Lots of postings on how to do this. Unfortunately, if your valve is old enough that it is stuck closed it probably has not been serviced in quite a while if at all. Try one of the less invasive methods to remove the valve first such as
using a crowfoot wrench slipped under the vale on its mounting hex. If you see the cast metal part the valve is threaded into beginning to flex stop what you are doing!
If all else fails, spray some penetrating oil on the base of the valve, let it sit overnight and in the morning use a hole saw on the end of an impact wrench, from above, to drill through the valve's sheet metal housing and tear the entire valve housing free of its mounting hex, Then a regular old hex socket mounted to the impact wrench slid over the valves hex base will remove what remains of the valve. Not the first method to try, but it certainly will be a final method if used.
Old 10-01-2018, 03:05 PM
  #627
PRSWILL
PRSWILL's Avatar
That's basically what I had to do! I pounded a 21MM socket over the bottom half of the valve and was able to free it- WHAT A PIA!!
Old 02-16-2019, 11:20 AM
  #628
John Crisalli
John Crisalli's Avatar
Default SAI circuit board
Hello to all...
I've been a member for a long time, but just reconnected with Rennlist recently. The photos in this thread don't come through. I've tried my pc, mac and ipad using both Firefox and Safari. The photos stay blocked through all 3 platforms even after turning off virus blocking.. So now I have a question: is there any other way to access this thread and be able to see the pix associated with this thread?
Thank you.
JC
98 C2S widebody
Old 04-19-2019, 11:53 AM
  #629
Sagres74
Sagres74's Avatar
Originally Posted by John Crisalli
Hello to all...
Thank you.
JC
98 C2S widebody
Is it just this thread? It might be an issue with the old posts and the sites that hosted the photos. Many sites seized to exist or changed their practices where they no longer allow free hosting.
Old 07-21-2019, 02:54 PM
  #630
Blue Ocean
Blue Ocean's Avatar
So has there been any definitive conclusion that this circuit works on '97 and '98's??
Quick Reply: Recap of the SAI circuit
