993 Forum 1995-1998
Sponsored by: DashLynx
rear stoneguard replacement
Old 11-08-2011, 12:10 PM
Mike W
Mike W's Avatar
Default rear stoneguard replacement
Can anyone advise as to cost and who would do this?
Old 11-08-2011, 12:22 PM
Spidey 993
Guest
Posts: n/a
Fairly simple process, hair dryer for heat to slowly pull them off.
Buy the new stone guards from FD Motorsports ($90ish) , put them back on. FD even gives you a template to try for practice.
Old 11-08-2011, 12:25 PM
Mike W
Mike W's Avatar
Is that $90 each or for the pair? thanks
Old 11-08-2011, 12:26 PM
Spidey 993
Guest
Posts: n/a
http://fdmotorsports.net/index_files/Page423.htm
Pair
Old 11-08-2011, 12:34 PM
No HTwo O
No HTwo O's Avatar
FDM's appers to be the way to go. An OEM stoneguard from places like Sunset are about $90 each.
Old 11-08-2011, 12:55 PM
95C4VanIsle
95C4VanIsle's Avatar
I have heard that the stone guards can come off in lots of little pieces which can be a PIA. Sometimes the removal leaves glue residue as well which must be removed but I don't think that is difficult to do.
I watched as mine were replaced recently. Mine had been on the car since new and I had read somewhere on RL that the older they are the more difficult it is to remove them in one piece. The guy heated up the stone guards with a heat gun until he felt it was the proper temperature (I would guess warmish, not hot) and started pulling from the rear most portion of the stoneguard. He pulled constantly at approximately a 45 degree angle with one hand and used his other hand, closer to where the stone guard is attached, to increase that angle to about 60 degrees. He repeated the process until the stone guard was totally removed. There was no glue residue left on the car. It took him about 1 minute per side.
Old 11-08-2011, 01:25 PM
Arena993
Arena993's Avatar
Just replaced mine. I change them every 2 years and they pull off in one piece. I can pull both sides off and install new ones in under and hour. If they have been on for a long time I would use a heat gun and adhesive remover to get them off.
Mike
Old 11-08-2011, 03:41 PM
RC DOUBLE
RC DOUBLE's Avatar
Mike
Nice to know they can come off this easy, mine are the originals on my car
and I was thinking of replacing mine as well. Thanks!
Old 11-08-2011, 04:00 PM
Mike W
Mike W's Avatar
Found a guy locally who claims he can do this with guards for under $200. Something called supershield. Will do on Friday. Pray for me......
Old 11-08-2011, 04:23 PM
MarkD
MarkD's Avatar
Mike, only word of caution is to be sure he is using 14 mil material
The thinner 8mil material will work to some extent.
If you get hit with a slightly larger rock... then, not so much.
Old 11-08-2011, 04:31 PM
Mike W
Mike W's Avatar
thanks Mark - I will be sure to ask.......
Old 11-08-2011, 05:51 PM
Arena993
Arena993's Avatar
Well I should be OK since I buy them from you guys.
Mike
EDIT: Whoops I assumed I was the Mike you were telling. Back to your regular programming
Quick Reply: rear stoneguard replacement
