993 Forum 1995-1998
Sponsored by: DashLynx
993 RS Steering Wheel Installed - wiring photos
Old 01-15-2024, 06:18 PM
  #166
Patinamisfit
3rd Gear
Patinamisfit's Avatar
Default 964 shroud
Hello
Great thread
I wondered if any one would know if the 964 shroud would fit and thus fill the gap on a 996/986 steering column and described it helping on a 993.
Old 01-15-2024, 06:53 PM
  #167
71-3.0-911
71-3.0-911's Avatar
The 964 column will likely not work due to the substantial difference between the dash and columns. One could always purchase and try. If it doesn't fit, return it? Very little transfers between air and water cooled cars besides some of the rims/wheel combos.
Old 01-16-2024, 03:15 AM
  #168
Patinamisfit
3rd Gear
Thanks for reply. I've found though that a lot of the parts on the 996/986 platform do have 993/964 parts, the std 4 spoke steering wheel is 993, a lot of the hand brake mechanism is 964. The clock switch, airbag plugs etc are the same as 993 etc. Just wondered if anyone knew before I brought one , took my car apart to find it didn't fit. To see if it's better with a Momo wheel or fitting a 964 part is a backwards step.
thanks.
Old 01-16-2024, 06:08 AM
  #169
TakeFour
TakeFour's Avatar
Why not ask the 996 guys what they are doing?
Old 01-16-2024, 06:14 AM
  #170
Patinamisfit
3rd Gear
Sorry yes I'll go back to the water cooled side of the forum.
Old 01-21-2024, 07:22 PM
  #171
SGOGT4
SGOGT4's Avatar
Just working to compile my parts to do a non-airbag conversion. Couple of Qs on the resistor, what’s the difference between 1/2W and 1/4W and which do I want/need?
struggling to find 2.8ohms looks like some use 3 ohms what’s the right guidance here and any suggested sources?
Old 02-26-2024, 10:02 PM
  #172
Goose 993
Goose 993's Avatar
Would this work in place of cutting up a 996/986 clockspring? Ebay item
Old 02-26-2024, 10:39 PM
  #173
SGOGT4
SGOGT4's Avatar
Answering my own question now that my install is done, Used a .5 W 3 ohm resistor and had no problem.
Old 04-24-2024, 10:06 AM
  #174
VladiD
VladiD's Avatar
so I was trying to order the connector pin for pin 71 in order to get a horn to work with my new Momo wheel, but Pelican says that they have no place to source the 999-652-639-22-OEM
Any idea what an equivalent, non-Porsche part would be from a company like Mouser?
Old 04-24-2024, 10:58 AM
  #175
71-3.0-911
71-3.0-911's Avatar
Just leave off the OEM suffix on the part number. Looks to still be readily available.
https://porsche.oempartsonline.com/o...ve-99965263922
VladiD (04-24-2024)
Old 04-24-2024, 12:20 PM
  #176
VladiD
VladiD's Avatar
Thank you!
Old 04-24-2024, 12:23 PM
  #177
71-3.0-911
71-3.0-911's Avatar
Also, I may have some of these just sitting around. I'll dig through my bins to see what I can find. If I remember correctly, I had to order like 5 of them but only used the 1.
Old 04-24-2024, 12:24 PM
  #178
Cupcar
Cupcar's Avatar
$!.34 at Delaware Porsche https://www.delawareporscheparts.com...ve-99965263922
Old 04-24-2024, 12:38 PM
  #179
VladiD
VladiD's Avatar
I'd love it if you had an extra one. Of the two places I ordered from, both canceled the order due to the unavailability of the item and no ETA.
Old 04-24-2024, 05:28 PM
  #180
UserA
UserA's Avatar
I'm always shocked at how a thread like this pops up right when I need it! I literally open the box from Gert with my steering wheel, a horn thingy and a capacitor. I only knew what one of those things was for until reading this!
Quick Reply: 993 RS Steering Wheel Installed - wiring photos
