993 Forum 1995-1998
Sponsored by: DashLynx
993 RS Steering Wheel Installed - wiring photos
Old 11-27-2011, 07:49 PM
ToSi
ToSi's Avatar
Default 993 RS Steering Wheel Installed - wiring photos
Took a few pictures while installing a new 993RS steering wheel this weekend. While I was able to find plenty of threads & general info about the wheel/hub, the wiring bits weren't documented so well & lead to a few surprises.. hopefully these help someone else.
The clockspring connectors are interchangeable between 993 / 996 / 986 Boxster. Ordering the wheel from Carnewal gets you the wheel/hub (duh), horn contact plug/pin, & the 2.8ohm resistor.
Part#'s:
Wheel + Hub assembly: 993-347-084-80-8YR
Horn switch contact: 964-652-104-00
Airbag connectors: tbd
Pin for turn signal switch connector: 999.652.639.22 (Identified by Cupcar here -> https://rennlist.com/forums/9314265-post1.html)
Before we begin, some disclaimers are necessary due to the sensitive subject matter of defeating a supplemental restraint system:
1) By opening this post, you agree to hold the author (me!) completely non-liable for any consequences you incur (or do not incur) as a result of this post.
2) You fully understand the implications and bear the burden of removing an airbag from a vehicle, should you choose to & will not look to blame someone else (especially me) for an undesirable consequence of your actions.
3) You read this on the internet. If something goes wrong, think of how stupid you'll sound when you proclaim to your spouse, significant other, parol officer, parents etc.. 'but I read it on the internet'. Say it out loud now, in the presence of another human to convince yourself how silly this excuse sounds.
4) Your car wants you to die & will try to kill you whenever it gets an opportunity to do so. It is dangerous by nature. Do not assume that because you've named it & have 'love' for it that this isn't true. You're the frog to Porsche's scorpion here..
Disconnect the battery, wait for good measure, then remove steering wheel (covered elsewhere, here's a good link -> https://rennlist.com/forums/8877053-post1.html):
Loosen this 8mm bolt to free the switch assembly:
Wiring bundle happily tied back for ~15yrs:
Taking a closer look, later cars (9*6) will have one orange, one red connector - they are interchangeable:
p/n 964.652.104.00
Presses in from the front:
& pokes through the switch..
adding another pin (#71) to the rear:
Problem is that this pin isn't populated in the mating connector since the horn circuit is carried through the clockspring in airbag equipped cars (photo upside down, look at the upper left cavity in the connector):
[/IMG]
Opening the connector & viewing from the backside:
Goals -
1) populate Pin71 (Horn circuit) & provide connection to horn circuit in 'OEM-like' manner. ** P/N for Pin 71 is 999.652.639.22 **
2) Fool airbag diagnostics to prevent fault code / warning light.
Rules -
1) do no harm - no cutting of underdash harness or hokey wiring that can fail, short, or cause future headaches.
Solutions -
1) obtain mating connectors from Porsche salvage yard (Oklahoma Foreign was accommodating & helpful)
2) obtain 2.8ohm resistor to mimic airbag
3) make jumper harnesses as below:
Parts:
Airbag control module diagnostic foolery:
Horn wiring jumper harness (brown-only wire is the original ground, don't have the correct tools to de-pin these yet so it will wait as is):
Soldered & heat shrinked (use a glob of liquid electrical tape underneath heatshrink to keep moisture out):
Pin71 again - if you'd rather be 'creative', splice Pin71 to the brown wire w/ white stripe via any means possible. You've been warned though..
Populated into connector:
From the mating side:
plugged in (brown-only wire is the original ground, don't have the correct tools to de-pin these yet so it will wait as is):
Loosely secured with zip-tie:
Installation is the reverse of removal:
Column shrouds / trim reattached (replace with 964 parts for improved fit / finish - not pictured)
Horn contact rides along slip ring to complete horn circuit (wheel is upside down in photo, black tab must be on left side to install)
Adjust switch assembly to ensure contact to slip ring on hub (gently pull toward you until it touches the back of the wheel / hub), view from top:
Tighten 8mm bolt:
Attach connectors on backside of horn pad:
Test the horn!
(vid goes here)
Behold, a proper 3-spoke wheel:
Order 964 trim pieces to avoid gap w/ 993 steering column trim:
Last edited by ToSi; 05-01-2012 at 07:28 PM. Reason: typos, pin p/n (thanks Cupcar!)
The following 2 users liked this post by ToSi:
anguilla1980 (10-26-2021), nhlbug (08-04-2021)
Old 11-27-2011, 09:34 PM
JPP
JPP's Avatar
These wheels are so beautiful! Thanks for the nice write up.
Old 11-27-2011, 10:27 PM
Jim W
Jim W's Avatar
Nice write up. I am wondering if this moves the wheel closer to the driver?
I would like that if it did.
Old 11-27-2011, 10:56 PM
BLT4SPD
BLT4SPD's Avatar
GREAT write up! This wheel in on my "must have" list, so I Thank you very much for documenting the process!
Old 11-27-2011, 11:59 PM
ToSi
ToSi's Avatar
Thanks, The RS wheel is 360mm (vs. 380mm) in diameter, moves ~10mm closer to driver, & up by ~10mm due to an off-center adapter incorporated between the wheel & hub. Looks like a collection of standard Momo parts so it should be possible to use an additional spacer to bring the wheel even closer to the driver & mount 'on-axis'. So far, the offset hasn't bothered me though.
Old 11-28-2011, 11:30 AM
JPP
JPP's Avatar
^^^ I think Porsche also offered a 'hub system' that brought the stock wheels further aft for tall drivers .. and it was probably either Momo or Nardi based as a vendor.
Old 11-29-2011, 09:37 AM
frenchclubsport
3rd Gear
frenchclubsport's Avatar
I did this upgrade last sunday.
You also have to change the "standard switch housing" in 3 parts by a "993 RS switch housing" : for just 60$ more.
ref.:
964 552 273 0 & 964 552 273 1
Old 11-29-2011, 01:22 PM
csmab
csmab's Avatar
When you disconnect the battery is it sufficient to just disconnect the negative terminal or should you disconnect both positive and negative? I know it is a lame question but I will be replacing my wheel in a couple of months.
Old 11-29-2011, 06:03 PM
frenchclubsport
3rd Gear
Just the negative is OK.. the most important is to wait for 30minutes.
Old 01-01-2012, 07:57 PM
windydog
windydog's Avatar
Update: I guess the correct question is how do you align the tab with the hub? I have been playing with it for a while. I can't seem to find the sweet spot where the horn will work when I start to turn the steering wheel.
What is the trick???
Old 01-01-2012, 08:32 PM
ToSi
ToSi's Avatar
No tricks, make sure the hub is snug & fully seated. Then pull the switch assembly gently towards the wheel. If the hub is cocked, the tab won't remain in contact w/ the slip ring & you'll have the issue you describe.
Like this:
nhlbug (08-04-2021)
Old 01-01-2012, 11:03 PM
windydog
windydog's Avatar
I will continue to play with it. Hooking up the horn has to be one of the most fustrating things i did all week.
Thanks for your post! It really helped me out. If you lived in Orange County I would buy you a beer!
nhlbug (08-04-2021)
Old 01-02-2012, 01:24 AM
tdarby
tdarby's Avatar
I have one of these wheels brand new in box i would sell. pm me if interested.
Todd
Old 01-02-2012, 02:03 PM
chris walrod
Guru
Rennlist Small
Business Sponsor
chris walrod's Avatar
excellent write up!!
Old 01-03-2012, 02:52 AM
csertich
csertich's Avatar
Great writeup!. Beautiful wheel. One of the best!
chuck
Quick Reply: 993 RS Steering Wheel Installed - wiring photos
