993 Forum 1995-1998
100% plug'n'play aftermarket ECU for our cars for under $1000
Old 01-05-2012, 07:14 PM
Juha G
Juha G's Avatar
It looks like there is interest so I will tell my friend to start working on the 96 ECU.
I think the best approach is that we first test a prototype on my 993 and dial in some base ignition and fuel maps. I estimate this take a couple of weeks.
Once that is completed, I will ship the prototype to someone over in US to try it.
It must be someone who is willing to spend time on testing it and must have a professional tuner with a dyno close by. I would be really happy if it was one of the tuners that frequent here on RL (like Viperbob, Bill Verburg etc.)
If the ECU is deemed good, then my friend could start making them for sale. I think earliest that could be by summer time, depending on how everything goes.
He propably cannot make more than 2-3 ECU's /month.
We have to keep in mind that this is only a hobby for him, he's got his dayjob as a research scientist in automotive industry (vehicle electronics RnD) and his also got two little kids and a wife who need some attention too...
M. Schneider (06-10-2021)
Old 01-05-2012, 07:15 PM
brucec59
brucec59's Avatar
How is this different from a chip (other than it can be reprogrammed on a PC)? Can we expect similar HP increase to your Motec? Thanks.
Old 01-05-2012, 07:16 PM
goofballdeluxe
goofballdeluxe's Avatar
It sure sounds interesting to me....I'd love to know more and see how this turns out.
Old 01-05-2012, 07:25 PM
chaoscreature
chaoscreature's Avatar
This is different from a chip from the standpoint that this would be a complete replacement of the original system with a totally new processor. This is more akin to installing Motec, or a universal DFI kit, but without the mess of re-wiring.
Sounds like fun!
Old 01-05-2012, 07:27 PM
Juha G
Juha G's Avatar
What this is, is a engine management unit that can be easily programmed.
A chip is something that is pre-programmed and inserted into the ECU (not possible on 96's). The maps on the chip cannot be modified on the fly.
There cannot be any promises for power gains. It is all up to the engine (including intake, exhaust) and the tuner.
My understanding is that Porsche left some hp/tq on the table with the stock fuel and ignition maps, mostly due to emissions etc.
So yes, there probably is some power to gain from a stock engine but I think this is better suited to modded engines and not only for getting the best power out but to guarantee a proper air/fuel ratio (important for the longetivity of the engine). Which was actually the very reason I put Motec on my car in the first place...
Old 01-05-2012, 07:30 PM
Juha G
Juha G's Avatar
Sounds like fun!
You can install a Motec without re-wiring. I did it and I am willing to share the information if someone is looking into doing the same thing.
However, Motec M600 is about 3000USD at the moment I believe? (I paid 2000euros but I got it cheap at the time) so that is why I think there might be interest for the ECU my friend could make.
Old 01-05-2012, 07:40 PM
chaoscreature
Excuse my ignorance on this but I was under the impression that a Motec conversion required an "adapter" that had to be made. My bad if this is not the case.
Old 01-05-2012, 08:06 PM
User 122821
User 122821's Avatar
The real question for US use is if the replace ECU will respond to OBDII queries from SMOG testers. Otherwise this may be a race only device.
Old 01-05-2012, 08:13 PM
chaoscreature
If it's truly as easy as unplugging/plugging the ECU back in then I dont think smog will be much of an issue. Easier than replacing exhaust every 2 years!
Old 01-05-2012, 08:28 PM
luial
luial's Avatar
Count me in as well. Very Interested for my '98 C2S
Old 01-05-2012, 08:32 PM
NP993
NP993's Avatar
I'm interested. Would also be curious to hear from experienced engine software guys what exactly the benefits are of an entirely new ECU (it's not Motec -- so what kind is it?) versus programming a chip. For example, I sourced a '97 ECU for my '96 993 that I'm planning to use for when I freshen up the motor and do RS cams or 9M top end. Are there limitations to the flash-able Motronic ECU that don't exist with a different, more modern, computer?
I guess the question really is -- Is the benefit of an aftermarket ECU simply the fact that it's programmable while the stock ECU is not, or is it that the programming resolution for fuel/ignition maps is superior to stock?
Old 01-05-2012, 08:42 PM
Jeff96-993
Jeff96-993's Avatar
Add me to the interested list.
Old 01-05-2012, 08:45 PM
Analog Theory
Analog Theory's Avatar
And me
Old 01-05-2012, 08:55 PM
Teddy2
Teddy2's Avatar
please couny me in
Kind reagrds
Dave
Old 01-05-2012, 08:56 PM
Mike J
Mike J's Avatar
That would be cool - I am interested but not sure how it would work with a Turbo...
Quick Reply: 100% plug'n'play aftermarket ECU for our cars for under $1000
