Leaking 1998 993 engine
suddenly got a constant oil leak. I trust my mechanic, recommended through my local porsche regions magazine, but are there any tests ,ways to definitively say where the oil is coming from? I am not mechanically inclined. a buddy said there is an additive you put in the oil that lights up under a special light that would show where its leaking! Any help would be appreciated.
How about you take this opportunity to get to know your car a little? Why don't you crawl under your car and take a look? There are a couple of locations that are notorious for leaking oil.
1) Lower valve covers and
2) Timing chain covers.
This is not rocket science.
How dirty is the engine? I need to find what is leaking on mine as well, but is dirty. So im going to spend a weekend cleaning it up with degreaser and then seeing exactly where it is coming from. There are some threads about leaks coming from the seals on the bolts.
phil.
phil.
If your car still has the engine under tray installed (let's not get THAT issue restarted), you will need to unbolt it to get a look at the actual engine to clean/find leaks. Easy peasy.
Also, some MY '97/98 motors developed leaks from faulty head gaskets. Porsche fixed cars still under warranty through a set of TSB's .. you might contact a dealer and see if there's any record of your car having any problems like that on the books.
Seared
Seared
Spectrum Naturals. I have a wholesale account with them, so I'm able to purchase the oil in 5-gal containers.
I did for the first few years of 993 ownership. Then I read a tech article on the Internetz that suggested using the blinkers dry, as the blinker fluid just adds weight and makes sloshing sounds when you check the car's shocks.
Andreas
Andreas
