Wiper Blades
Wiper Blades
I bought a new set of wiper blades (top of the line from Autozone) a few weeks ago and while they do a good job cleaning the windshield, they hang over where the windshield curves on the drivers side. It leaves a bunch of crud on the windshield at that location...
Are the OEM blades the only option for a good fit here or has anyone had a good experience with aftermarket blades...I know it seems trivial but I like a clean windshield.
thanks,
Mark
thanks,
Mark
I have not had much luck with third party blades, but that does not mean they do not exist. The posche blades are expensive for sure, so it would be interesting to see if alternatives exist.
Cheers
Mike
Cheers
Mike
I measured my old blades and went into the Autozone to buy new ones. The guy looked in his book and quoted a length 1" longer on one blade and 2" longer on the other than I had measured. Left the store and ordered them from Pelican.
They came separately in Bosch boxes...$7.75 per blade.
When parked the tip of the bottom (L) wiper stands slightly out from the glass a small amount because of the windshield curve. The top (R) wiper does not hang of the glass.
There are far far worse problems....
Last edited by Jack of Hearts; 01-20-2012 at 05:34 PM. Reason: looked at them again
BTW from dealer, they have Bosch engraved on them, but no squeal ;p
Can't just the insert be changed on the stock wiper blades? I know that most parts stores don't carry the inserts anymore but I think you can still get them from VW dealers.
GC
GC
Former Vendor
We carry PIAA Super Silicone blades and the work AWESOME. I have tried many of them myself and these really do work great. It's all I use. I do have an 18" curved passenger blade that should fix you up.
You can order here.
Here is a link
You can order here.
Here is a link
Noodle Jr.
You can order here.
Here is a link
You can order here.
Here is a link
You can order here.
Here is a link
You can order here.
Here is a link
I got these a couple months ago from you guys. The left wiper does stick up off the windshield a bit. Are you saying there's a different part that wouldn't do that?
