993 Forum 1995-1998
Sponsored by: DashLynx
I Replaced odometer gear without removing speedometer needle and gauge plate.
Old 03-26-2012, 12:49 PM
sbarracl
sbarracl's Avatar
Thanks for posting the video. I wound up replacing my gears a couple weeks ago. I tried to do it the way you described, but wound up just removing the needle and the speedo face. It came off easily enough followng the instructions on p-car.com and gave full access to the motor. It's always appreciated to see alternatives...
Old 03-26-2012, 01:41 PM
jo-hans
jo-hans's Avatar
Thanks for the video!
I did however replace the gears a couple days before you posted the video. I did manage to completely get the motor unit off so I did not need the use of the tweezers. The gears that came off mine were still in pretty good shape - I did not have any odometer issues yet. Just preventative as I had the front off to replace the plastic lens to a glass one anyways.
The most time consuming part is removing the ring surrounding the plastic lens.
For those that needed to replace the broken gears I recommend to replace the plastic lens to the glass one you can buy for $12 from NHS. The glass looks so much better and matches the other glass dials.
cheers
Old 03-28-2012, 04:31 AM
mgianzero
mgianzero's Avatar
Thanks for the comments everyone. Just glad to help out fellow Rennlisters as I have found a lot of useful information on this website for myself over the years.
I got a little crazy and edited my video for HD and some text edits.
Here's the new link:
Enjoy -
Marc
Old 03-28-2012, 01:28 PM
f8vr993
f8vr993's Avatar
Good job bro!
Old 03-28-2012, 04:09 PM
SkiDan
SkiDan's Avatar
Excellent resource for future reference. Thank you.
Old 03-28-2012, 10:52 PM
funbug
funbug's Avatar
Thumbs up
Thanks! Perfect timing. Mine also broke and needs replacing.
Old 04-04-2012, 11:01 AM
01coccobet
01coccobet's Avatar
great job…..
Old 04-04-2012, 11:29 AM
FisterD
FisterD's Avatar
Nice. Excellent video DIY.
Old 04-04-2012, 01:09 PM
abiazis
abiazis's Avatar
Great job.......awesome that you did the video........
Getting that bezel off for me was the hardest part.....patience is the key in not damaging it......as you just want to rip that thing off!! I know I would have sworn during the video.....nice job.....
Like the skilled tweezer method to remove and replace, don't know if that is easier though than disassembly.........to each their own as they do the job............
Thanks for the great video..........I autographed the back of my speedo with a marker when I was done with the fix miles indicated.......and dated it......
Old 06-21-2012, 10:29 AM
panicosc
panicosc's Avatar
Hi guys, my 964 has the same problem. Changed the gears but still not working. It does not count miles. Only shows the speed.
Any ideas. What else i can do?
To be honest im about to replace it with a new VDO or a GPS speedometer even though i will loose the the auto open of the rear spoiler.
Any help is most welcome
Old 06-21-2012, 02:51 PM
KLSpeed27
KLSpeed27's Avatar
Mine too...ordering a new one today!
Old 06-21-2012, 05:49 PM
Ricky_D
Ricky_D's Avatar
That is great info, mine just broke last week.
Anyone know the procedure to also convert the speedo to KM/H while fixing the gears.
Old 08-25-2012, 03:34 PM
Pete Lech
Lifetime Member
Pete Lech's Avatar
Marc, perfect timing to find this link as my odometer recently quit. Thanks for the DIY video.
Old 08-26-2012, 01:08 AM
epj993
epj993's Avatar
As a point of reference, I recently had this same issue. Not wanting to tear my speedo apart, I sent it to North Hollywood Speedo. Cost was $130, turnaround 5 days.
Old 08-26-2012, 06:45 AM
Franklin229
Franklin229's Avatar
Great video-Mine still works but you never know when its going to go-
Quick Reply: I Replaced odometer gear without removing speedometer needle and gauge plate.
