993 Forum 1995-1998
Sponsored by: DashLynx
Fuel Door Doesn't Close
Old 05-21-2012, 01:48 AM
jimhsu
jimhsu's Avatar
Default Fuel Door Doesn't Close
Hello:
Opened the flap door to fill up but the door does not snap and stay closed. Drove home with the door flapping up and down. Since it is in my plain sight, it makes the driver (me) look extra stoopid. I did notice that if I drive faster than 55mph the wind keeps the door mostly down (not fun when there were a few speed traps and 30mph zones on the way home).
I do see the latch move a little bit when I pull the lever. Is the cable too loose? Has anyone had this problem? I haven't seen too many threads about this on the 993.
Thanks!!
Old 05-21-2012, 09:40 AM
techman1
techman1's Avatar
Try moving the latch the door should catch on all the way left.
Mine also seeems to stick a little. When I pull the lever, it pops open. I fill-up, then move the latch a little, then close the door.
When this gets old, I will take the time to fix it!
Old 05-21-2012, 09:43 AM
justin993
justin993's Avatar
It is adjustable.
Also, sometimes the **** that you pull manually can get hung up on the inside when you pull it - the base of the **** can hang up on the hole in the dash.
You can also move the latch of the fuel door back or forth by had to get it to catch the door if you are having problems getting it to catch at the station.
Old 05-21-2012, 01:55 PM
The Brewmeister
The Brewmeister's Avatar
Also make sure the cable isn't sticking and causing the latch to remain open.
Old 05-21-2012, 04:16 PM
NP993
NP993's Avatar
It's a really simple mechanism. ****, cable, latch. If you take 10 seconds and look at it you're all but certain to figure out why the door isn't staying closed.
Old 05-21-2012, 10:27 PM
Gt3 Racer RS
Gt3 Racer RS's Avatar
In the words of me, JUST SLAM IT!!!
Quick Reply: Fuel Door Doesn't Close
