Needed -Alignment and corner balance in Chicago land area
Does anyone know of a good shop that can do an alignment and corner balance on a 993. Called Napleton Porsche and they wanted to charge 580 just for the alignment plus an additional 4 hour to corner balance which I think is ridiculous.
I which I was a little closer to my old Porsche dealer in Michigan. They only charge 150 .
Anyhow, if anyone can recomend a good shop in the Chicagoland or Northwest area would be wonderful.
Thanks in advance,
Al Z
Thanks in advance,
Al Z
993 align/corner balance
Al--also try Euroquipe in St. Chas. (Tim Kautz). I've pm'd you his info. I know Fischer and PP also do good work--not sure whose least expensive as I have found "least expensive" and "Porsche" to be mutually exclusive terms.
Just wanted to revive this thread since I was looking for the same thing.
Perfect Power quoted me as much as $420
EuroSpeed quoted me $330
Fisher quoted me about $250
Rennology quoted me $200
Euroquipe quoted me $150
Can anyone else comment on their experiences with any of these shops? Specifically Euroquipe?
I have used Midwest Eurosport with success. I used Perfect Power once, and though they did a good job, I thought they were over-priced. The Exchange does not advertise this, but they have a very good air-cooled mechanic from what I have been told - you might give them a call.
Make sure you are comparing apples to apples..... Simple alignment vs. corner weight vs. setting ride height. Very different things.
I had Fischer do my 993. $250 is for camber / toe only.
Received 5,390 Likes
If it needs kinematic toe......add some more.
I trust Midwest Eurosport for both 993 and 968 P cars and would highly recommend. They have 2 locations - one in Joliet at Autobahn and one in Bensenville.
I picked my car at Perfect Power and met the owner Sol. Very impressive shop and selection of cars. If I was In Chicagoland, that's who would be doing the corner balancing and alignment for me. As to the cost, my local independent shop quoted $350 for corner balance and alignment, however they don't even own the kinematic tool and borrow it....hmmm. Some people are familiar with Autometrics who quoted around $450.
Yes it sounds like a lot, but if you figure a national average of $100 per labor hour at a shop, that's only 4.5 hrs.
After my recent installation of PSS10s and bushings, and a basic toe alignment, I believe it will take more than 4 hrs. The rear suspension has so much adjustment and especially the kinematic. Waiting for the suspension to settle a little and drive appx 500 miles before deciding on where to go.
