993 Forum 1995-1998
Sponsored by: DashLynx
Engine locked up on start up...catastrophic damage?
Old 09-07-2012, 02:07 PM
NP993
NP993's Avatar
Seems to me if there's a physical obstruction, it's not too hard to pull a spark plug from each cyl and then turn the motor over by hand to try to get a feel for it -- maybe even listen with a stethoscope to try to locate the "clunk." That is, unless the motor is completely seized.
Old 09-07-2012, 03:10 PM
Bruce SEA 993
Bruce SEA 993's Avatar
Location: Lat: 47 Deg 26.848N Lon: 122 Deg 21.341W Seattle
It could be hydro locked from a leaking fuel injector...in which case removing the spark plugs would reveal it.
Tried not to speculate...but couldn't help myself! I hope it turns out OK for you!
Old 09-07-2012, 05:26 PM
TRINITONY
TRINITONY's Avatar
Originally Posted by Bruce SEA 993
It could be hydro locked from a leaking fuel injector...in which case removing the speak plugs would reveal it.
I was thinking the same thing.
Old 09-07-2012, 06:54 PM
95carrera
95carrera's Avatar
Thanks to all. This truly stinks. This is why any new buyer should have a 5k reserve set aside.
"Trophy" may have it, spoke to mechanic this afternoon, said everything looked good inside chain boxes. He thinks its the torque converter. As engine came out to do chain boxes, maybe didn't get put back together correctly? Not sure. His inspection will continue Monday morning.
We agreed this is good news. Not that any if this is "good" but could be worse apparently.
Will know more Monday.
Old 09-10-2012, 11:51 PM
Cemoto
Cemoto's Avatar
Any updates?
Old 09-10-2012, 11:56 PM
ginch
ginch's Avatar
Your so smart Stephen!!!! Hopefully it doesn't cost you too much to fix and your out and driving again soon!!!
Old 09-11-2012, 09:20 AM
os993
os993's Avatar
I'll also chime in here and say very sorry to hear about this, and this is definitely not something a three week old owner should experience.
Hang in there, and work it out, as it appears you are doing. Good luck and please keep us posted.
Old 09-12-2012, 09:04 AM
95carrera
95carrera's Avatar
Thanks again to all. Spoke to shop yesterday, said it was the starter binding the engine. Appeared as if it broke apart or something. This is a tip car. Said this was "good news". Said the transmission should not be damaged. Thought it was a matter of trying to figure out why it happened, to recover all lost pieces from the starter assembly and replace or rebuild any damaged parts. It is going very slow, but I guess this is good news. I still have not heard of this happening to anyone else with one of these cars. The engine was out with the PO in March, so maybe they didn't get it all back together correctly? Who knows. It did not give any warning signs of any mechanical problems prior to locking up.
Old 09-12-2012, 10:43 AM
1stgear
1stgear's Avatar
Good news indeed. When I bought my 993 in December, I had a PPI and then wound up having to do a full top-end rebuild to the tune of $11k. And I was without the car for a total of 7 weeks. Just remember, things can always be worse.
Old 09-12-2012, 11:02 AM
doc_porsche
doc_porsche's Avatar
So stressful reading this... Hopefully or glad its not bad
Old 09-12-2012, 06:26 PM
Dryfly57
Dryfly57's Avatar
I'm with "doc_porsche", I'm sick just reading this thread.
Hope you get your wheel on the road sooner that later!!!!!
Old 09-12-2012, 06:45 PM
trophy
trophy's Avatar
Good they have found what the issue is.
When they pull it out just make sure they check for damage around the engine case. For it to stop the engine the pieces would have been caught between the ring gear and the engine case (to lock up).
There are a number of supporting ribs at the back of the case that could/would catch any debris and stall the engine.
Old 09-12-2012, 08:07 PM
XavierLaFlamme
XavierLaFlamme's Avatar
That's relatively good news.
Old 09-12-2012, 10:10 PM
J.B.H.
J.B.H.'s Avatar
How sure are you the engine locked up? Engines can make sounds that sound violent to some people...Dont assume the worst...see what your wrench comes back with... -good luck
oops missed page 2
Old 09-12-2012, 10:57 PM
vincer77
vincer77's Avatar
So maybe what happened is the bendix did not retract when the engine started which then probably got ripped up. Glad I ordered a new starter.
Quick Reply: Engine locked up on start up...catastrophic damage?
