993 Forum 1995-1998
Sponsored by: DashLynx
Engine locked up on start up...catastrophic damage?
Old 09-06-2012, 09:36 PM
95carrera
95carrera's Avatar
Default Solved: Engine locked up on start up...catastrophic damage?
Started my new to me 95' after sitting over weekend. Violent noise, engine locked up. Towed to shop, not the starter, pulling engine to open up chain boxes. Waiting to find out extent of issue.
This could be a nightmare. Had PPI done, nothing significant, appears to be solid car, put 600 miles on car in last three weeks, no major problems.
I have never read about this issue. What could have happened? How likely is it that valve train is damaged? I am sick about the thought of doing a top end rebuild on a car I have owned three weeks.
Old 09-06-2012, 09:43 PM
goofballdeluxe
goofballdeluxe's Avatar
You could be doing more than even a top-end rebuild, you could be doing much less.
We could arm-chair quarterback for you, but the info you get from the mechanic will be much more definitive. Be prepared for a massive bill, and if it is, you're ready. If it's not, you get to be really relieved.
Sorry to hear this. I have no idea what it could be, but pulling the engine out and opening it up is already getting expensive.
Best of luck.
Old 09-06-2012, 09:57 PM
Jeff96-993
Jeff96-993's Avatar
Ouch! Sorry to hear about this problem... it's not the norm. How handy are you with car repairs? If you're not, do you have a good Porsche mechanic familiar with air/oil-cooled engines?
Without knowing the cause, no one can really guess a cost estimate.
Old 09-06-2012, 10:16 PM
95carrera
95carrera's Avatar
It's at independent now. BTW car has 93k on it, recent service included replacing chain box gaskets by PO.
Old 09-06-2012, 10:20 PM
Mark in Baltimore
Mark in Baltimore's Avatar
Best of luck.
Absolutely sound advice. Good luck!!
Old 09-06-2012, 10:49 PM
race911
race911's Avatar
Not to get into the above-mentioned armchair QB'ing, but you started it, it ran................for how long..........idled..........moved under its own power.............and then the noise came.
Old 09-06-2012, 11:01 PM
95carrera
95carrera's Avatar
Never moved, it immediately stopped. Ran for literally a few seconds. Thought I threw a belt or something.
Old 09-06-2012, 11:08 PM
race911
race911's Avatar
I don't see how it could have puked a tensioner and lost cam timing. But what you describe was a monthly occurrence when I had both of my shops going from '85-'95! Broken valve spring and sucked a valve? When the yellow car pulled that trick from the Aase valve springs the car was actually street licensed and it happened to me on startup in the hotel parking lot. Drove it to the track, but only found a single bent intake from two broken intake springs.
Guess I should ask the question--do you think in any way, shape or form overrev'd? (Of course you'll tell us it's a tip...............)
Old 09-06-2012, 11:22 PM
95carrera
95carrera's Avatar
LOL, it is a tip. No over rev. Just turned the key to leave for work, it is my DD.
Old 09-07-2012, 01:21 AM
MielsOnWheels
MielsOnWheels's Avatar
Man I am sick hearing about this, especially with a car you've only had a couple of weeks. I hope it's something simple...best of luck
Old 09-07-2012, 09:49 AM
solomonschris
solomonschris's Avatar
This is really a bummer. I just would reiterate how important it is that the mechanic be experienced in the air cooled 911's. Even if you have to put the car on a roll back to deliver it to the right guy for several hundred dollars, it will be money well spent. Good luck.
Old 09-07-2012, 12:50 PM
gtroth
gtroth's Avatar
Wow, that's rough. Best of luck.
Did the PO drop the engine to do the chain cover seals?
Old 09-07-2012, 01:06 PM
trophy
trophy's Avatar
Sorry to hear this. Interested to hear what has happened. You may have lost a spring or maybe even a chain, but these usually happen at higher revs. It could also be transmission related, torque converter failure.
Keep us informed. hope it is simple for you.
Old 09-07-2012, 01:51 PM
Cactus
Noodle Jr.
Cactus's Avatar
+1!
Old 09-07-2012, 02:02 PM
ricks993
ricks993's Avatar
Violent noise is bad thing, with that comes a violent bill. Maybe it is something simple but if the engine is locked I hope you do not have a valve touching a piston or worse a valve broken into the piston. If you can talk to the previous owner you might be able to go after the shop that replaced the gaskets. It could be because the shop did something wrong causing a tensioner or chain to fail when replacing the gaskets especially if it was recently done. Your next decision” will be “while the engine is out you might as well do ………” With 90k and original clutch “might as well” replace. With 90k you “might as well” have the heads done, etc.
Good luck and as others have posted I hope you trust your wrench, because you are looking at a large bill, plus no car for some time.
Quick Reply: Engine locked up on start up...catastrophic damage?
