993 Forum 1995-1998
Sponsored by: DashLynx
Help, buzzing noise from dash
Old 09-27-2012, 06:54 PM
Jon93
Jon93's Avatar
Default Help, buzzing noise from dash
The last three times I've started the car, there is a buzzing sound which seems to come from the dash, roughly where all the warning lights are situated. The noise gradually goes away after approximately 30-45 seconds. (It does not coincide with any of the warning lights going out, such as spoiler or brake pressure).
Yesterday after driving to work, I turned off the ignition, and then restarted the car-on that occasion the noise did not occur. So in other words it seems to occur if the car is 'cold'.
Any ideas?...Thanks!
Old 09-28-2012, 02:55 AM
geolab
geolab's Avatar
solution in the 993 DIY section , regards
Old 09-28-2012, 04:34 AM
Stewart
Stewart's Avatar
With a C4 or C4S the brake boost pump buzzes away for the first few seconds after switch on and you may hear it now and again whilst idling. That's normal.
Old 09-28-2012, 02:57 PM
pp000830
pp000830's Avatar
Received 1,452 Likes on 1,023 Posts
Dust in the fan housing on the back of the Heat/AC control console. Console is released by putting coat wire hanger pins in the 4 corner holes, the unit pulls right out of the dash, disassemble the fan clear the dust put back in. I did this and the sound went away for 4 years. Needs it again now.
Andy :-)
Old 09-28-2012, 03:27 PM
mike cap
mike cap's Avatar
Andy :-)
Andy is correct. The CCU fan is loaded up with dust and lint. It pulls out easy after you press the pins in, then snaps back in place.
Old 09-28-2012, 03:31 PM
mgianzero
mgianzero's Avatar
I agree w/ Andy. The CCU has a fan in back which samples cabin air. The CCU is responsible for a lot of temperature analysis for heating / aircon and engine temp monitoring. It gets dirty and you can disassemble and blow it out. Common problem. Just do a search for CCU repair.
Marc
Old 09-28-2012, 09:06 PM
Jon93
Jon93's Avatar
Thanks for all the replies.
I took a quick video this morning on may way to work, sorry about the poor quality, but I think the buzzing can be heard ok, it went away about 15 seconds after the video finished.
Just wanted to confirm you all still think its the Ccu fan.
Cheers
Old 09-28-2012, 09:16 PM
NC TRACKRAT
NC TRACKRAT's Avatar
Get a Fister Stage III Exhaust! Then you won't hear the buzzing!
Old 09-28-2012, 09:36 PM
Jon93
Jon93's Avatar
Ps forgot to mention here is a far more entertaining video (IMO) of my boys watching a993 on YouTube. This was taken last year when I was getting ready to purchase my car.
Old 09-29-2012, 03:23 AM
geolab
geolab's Avatar
fantastic boys, congrats !!!
https://rennlist.com/forums/993-1995...-993-dash.html
Old 09-29-2012, 06:14 PM
NC TRACKRAT
Thanks to Geolab for the "cure"! Just this afternoon, my wife asked me "What's that buzzing noise after you turn off the ignition switch", so, (thanks to RL), I told her. Just finished the successful operation and would like to add a precaution:
When pulling off the black hose that goes from the fan to the front of the unit, be careful that the plastic sensor support just behind the front panel isn't dislodged. If it is, you'll need some long tweezers to carefully replace it in the cut-out on the round metal tube that's supposed to keep it in place. Don't yank on it because there's a thin sensor wire attached to it. After cleaning out the rubber tube, make sure the tube is inserted properly over that assembly. Then, re-install the fan to the rubber tube. Ah, "the sound of silence"!
Old 09-29-2012, 08:03 PM
mgianzero
mgianzero's Avatar
Glad it was what we thought. I'd hate to have you go through all that work with no improvement.
Geolab - your DIY was superbly written!
Old 06-20-2014, 04:54 PM
tcsracing1
tcsracing1's Avatar
great DIY!
Once you get the unit removed the hardest part is removing the two plugs and of course getting the two plugs back in.
My noise has now gone away!
Old 10-22-2019, 04:59 PM
nels415
nels415's Avatar
Default Buzzing noise still there
So I removed the fan and cleaned it, greased it, but still getting the buzzing noise. Should I try replacing the fan now? Anyone else have same problem?
-nels
Old 10-23-2019, 02:31 AM
Foxman
Foxman's Avatar
-nels
Over time the fans wear out. Bergville FX makes a Replacement CCU Fan
Quick Reply: Help, buzzing noise from dash
