993 Forum 1995-1998
Sponsored by: DashLynx
cdr 220 in 993--glove box now won't open
Old 11-17-2012, 05:39 PM
robingb
robingb's Avatar
Default cdr 220 in 993--glove box now won't open
anyone else has this problem?
Old 11-17-2012, 05:43 PM
timothymoffat
timothymoffat's Avatar
?????? Nope.
Old 11-17-2012, 05:47 PM
Mike J
Mike J's Avatar
How do you know its the Radio vs other issues that can happen (like loose latch)?
Old 11-17-2012, 06:10 PM
Avenger6
Avenger6's Avatar
yes.... did you just install it? You have to play with it a bit to get it so it doesn't push on/squeeze the little slider/retainer arm for the door.... if it does, the friction will keep the door from opening....just get the radio as far over to the left in the slot as you can.... even 1/8" will make a difference.... you could have also gotten one of the wires behing that hook, preventing it from coming down...
Old 11-18-2012, 04:43 AM
911PERVY
911PERVY's Avatar
Very common after an ICE install that the cable fouls the glovebox hinge, remove and replace stereo with more care!
Old 11-18-2012, 05:01 AM
CalvinC4S
CalvinC4S's Avatar
Yeah, the glove box door has a hook like stop that's catching your antenna wire.
Your going to have to pull the unit and reposition the wires.
Old 11-18-2012, 10:33 AM
x50type
x50type's Avatar
If the glove box is fine with the radio out, the radio cables are fouling the glove box retaining arm.
Pull out and replace radio keeping cables away from right hand side.
There is a narrow opening under the dash where a small hand can help to guide the cable as you push the radio back in.
Test glove box door opening as you push in radio.
Old 11-18-2012, 04:25 PM
vincer77
vincer77's Avatar
Change stations maybe? ;-)
Old 11-19-2012, 01:54 AM
2Many Cars
2Many Cars's Avatar
Advice above is right. It's a wire (probably the antenna wire) caught in the glovebox hinge stop.
Old 11-19-2012, 11:00 AM
x50type
x50type's Avatar
Unlikely antenna wire - it's on the left of the radio.
However, it's like a rat's nest behind the radio and as far as i can see, just a matter of luck where the cables finally come to rest, once the radio is fully seated.
Quick Reply: cdr 220 in 993--glove box now won't open
