993 Forum 1995-1998
Sponsored by: DashLynx
Official Tie Rod Pinning Tool Wait List Thread
Old 04-12-2019, 10:03 PM
  #256
samurai_k
samurai_k's Avatar
Pic to explain my question ...
Old 04-13-2019, 11:11 AM
  #257
OverBoosted28
OverBoosted28's Avatar
Just use your pic to estimate where to drill. About middle is fine. I actually put two pins in each TR, offsetting second 90° and about a 1/4”.
Old 04-13-2019, 02:38 PM
  #258
Garth S
Garth S's Avatar
Originally Posted by samurai_k
@Garth I am going to attempt to drill the pilot and final hole with my press. It is not clear to me where exactly you are to drill the hole in relation to the inner tie rod male and female ends. Can you help clarify? Eyeballing it looks like about the middle of the inner...
Thanks!
Nope!
The inner tie rod half is largely contained within a cylindrical 'can' of mild steer, ~ 1.5" diameter and 2.7" long ( on the outboard side extents the female threaded coupling to accept the outer tie rod threaded end, for adjustment of alignment toe-in. ..... the inner end has the ball swivel to attach to the rack rod)
The drill point is 19mm/ 3/4 inwards from the inner side of the 'can' that faces the rack/ball swivel. ie., inboard side of the inner tie rod
A through hole here avoids any contact with the outer tie rod threaded adjustment zone ..... as said long ago, to do the reverse will pin the two rod halves together ==== and seriously pi$$ off your alignment guy!!
PS - there's a good pic above in post #41. Alternately, search out my old posts on 'Anatomy of a tie rod'. Recall several pics there re pin location.
Old 04-13-2019, 06:57 PM
  #259
samurai_k
samurai_k's Avatar
Thanks @Garth S crystal clear!
I found your other thread here: https://rennlist.com/forums/993-foru...rod-inner.html
I noticed our originally used a Grade 10/12 hex bolt and then later switched to a pin. Is there any reason why one is better than the other approach? Seems like driling a hole, tapping it, then sending a hardened steel bolt through it and loctite would make it more secure than a crush pin?
Old 04-13-2019, 07:31 PM
  #260
Garth S
Garth S's Avatar
Never progressed to threading/bolting - the roll pin proved to be a mere elegant AND pragmatic solution. The radial force exerted by a compressed roll pin acts in an axial direction of both inner tie rod components. A bolt cannot do this.
That then provides a better locking of the two components, and neutralizes the effect of the rubber vibration dampening /steering 'slop'
Old 04-13-2019, 11:47 PM
  #261
samurai_k
samurai_k's Avatar
Thanks!
Old 06-01-2021, 07:07 AM
  #262
red64chevelle
red64chevelle's Avatar
Can I be added to the wait list to borrow the tool? I presume this is still the right thread for this?
Old 07-01-2021, 01:14 PM
  #263
red64chevelle
Anyone got a lead on the kit to do the install?
Thanks in advance.
Old 07-02-2021, 03:42 AM
  #264
samurai_k
samurai_k's Avatar
I never heard back from anyone so ended up using a drill press. Clamped the tie rod end to it. Worked perfectly.
Old 07-01-2023, 04:52 AM
  #265
Matthew So
Matthew So's Avatar
Sorry to bump a dead thread but anyone knows where the kit is at now?
Matthew
Old 09-24-2023, 10:57 AM
  #266
acr89
acr89's Avatar
Someone must know where the jig/tool is these days. I’d like to do the same thing on my 993 versus buying new inner tie rods.
Quick Reply: Official Tie Rod Pinning Tool Wait List Thread
