993 Forum 1995-1998
Sponsored by: DashLynx
Schnell Wide Oval Tips Installation
Old 10-13-2019, 03:30 PM
  #31
P-daddy
P-daddy's Avatar
Your mufflers are likely not OEM. Probably Schnell, Fabspeed, etc... No extensions available for this unless you have someone weld on longer outlet pipes.
Old 10-13-2019, 03:55 PM
  #32
pp000830
pp000830's Avatar
Received 1,455 Likes on 1,026 Posts
Riddle me this, do they make your exhaust Schnell better?
Old 10-13-2019, 04:17 PM
  #33
TheOtherEric
TheOtherEric's Avatar
I’ve never heard of any sort of short extension, What kind of idiot muffler maker would design it to require special tips?!?! Such idiocy. I’m guessing someone obscure like Billy Boat or such. Neither of those tips seems acceptable.
Old 10-14-2019, 07:33 PM
  #34
71-3.0-911
71-3.0-911's Avatar
The mufflers are likely old fabspeed max flows. I had the exact same issue and Darrin at FD Motorsports was able to fabricate some extension pieces so i could use stock tips. Older max flows had shorter output flanges due to the longer tips that came with them.
Old 10-14-2019, 09:06 PM
  #35
samurai_k
samurai_k's Avatar
Couldn't you just have a muffler shop weld on some new longer pipes with flange to make them similar to an OE muffler? If you need measurements I have my mufflers off and could send you some of you need them.
Old 10-14-2019, 09:25 PM
  #36
Fede-993
Fede-993's Avatar
Well first thanks everybody for the answers.
at this point I guess I’ll really have to go that route. weld.
I was sure it would have been the simplest plug and play job, and that’s why I had already painted the tips.......well....that’s the fun part.
ill definitely take measurements but definitely if anybody has done something similar or has mufflers not installed Samurai) it would definitely be helpful to address the job.
there are some extensions that I’ve seen online that you can bolt with clamps.....looks easier but still I think a good properly made weld will be the route to go...
Old 10-14-2019, 09:34 PM
  #37
samurai_k
samurai_k's Avatar
I'm travelling this week. I can share some pics and measurements next weekend if you still need them.
Old 10-14-2019, 09:36 PM
  #38
Fede-993
Fede-993's Avatar
no rush at all.
I’ll be in Los Angeles for work
Old 10-15-2019, 03:38 AM
  #39
911PERVY
911PERVY's Avatar
I wouldnt bother with other people measurements, they will be different to your car. Measure both and I bet they wont be the same! You want the tips to just clear the PU by about 15mm
Quick Reply: Schnell Wide Oval Tips Installation
