993 Forum 1995-1998
Sponsored by: DashLynx
Underbody Spray Coating Source?
Old 09-28-2016, 02:10 PM
NC TRACKRAT
NC TRACKRAT's Avatar
03584 is black.
Old 09-28-2016, 07:11 PM
Cemoto
Cemoto's Avatar
Is this what you are looking for?
Old 09-28-2016, 07:29 PM
911F1
911F1's Avatar
^ Expensive but it seems like this would work
https://www.amazon.com/3M-08889-Rock.../dp/B00HSCN8NO
Old 09-28-2016, 07:51 PM
Cemoto
Cemoto's Avatar
There is also this from the Stoddard catalog.
Old 09-29-2016, 09:29 AM
cobalt
cobalt's Avatar
Received 1,949 Likes on 1,180 Posts
Could be wrong but I was always told that Porsche used the Wurth product back in the day. AFAIK the gray is NLA I had a friend who has some NOS and you need the special (expensive) gun to spray it to get the proper texture. from what i saw it was a perfect match after you cleaned the grime off the balance of the area o be touched up.
here is the finished product using the older wurth product. The majority of this is original I only touched up the leading edge you can see a slight variation in color but I think that is just age and will probably blend better over time.
Old 09-29-2016, 09:41 AM
Cemoto
Cemoto's Avatar
That looks right on Anthony.
The 3M product comes out just a shade lighter.
That image from the Stoddard catalog showing the Wurth product is current, but I would have no knowledge of availability.
Thank you.
Regards.
Old 10-05-2016, 12:35 PM
onboost
onboost's Avatar
Anthony, you are correct, Porsche used the Wurth product and the grey is NLA as stated. Black is available, can be tinted (though its quite a bit of work) or painted, "the special (expensive) gun to spray it" has to be adjusted a bit (nozzle & air pressure) along with distance from panel plays a part in getting the proper look.
Also, UPOL offers a product in grey that is very close to the Wurth grey.
Old 10-05-2016, 08:52 PM
Paul902
Paul902's Avatar
Default Texturing technique
I've used the 08889 and was quite happy with the product. Later, I found this 3M video showing a technique to get a sprayed texture with seam sealer. It may work with the 08889, Wurth, or UPol. I have not tried it at home, yet.
Quick Reply: Underbody Spray Coating Source?
