993 Forum 1995-1998
Sponsored by: DashLynx
What is this and is it a DIY?
Old 10-15-2013, 08:11 PM
vern1
vern1's Avatar
Default What is this and is it a DIY?
Saw this tonight when i got home when i was checking my oil. Not sure when it ripped but havent noticed any effect on the performance. Seems to surround the fan housing but thats where my guessing ends
Is this part easily repairable? Any ideas on costs if its not a moderate diy? I can undertake relatively minor stuff but if it is too involved it will have to go to my indy
Any harm in driving it in the meantime?
Any thoughts appreciated
Old 10-15-2013, 08:12 PM
vern1
vern1's Avatar
Yikes sorry about the picture size. Dont know what to do about it now!!
Old 10-15-2013, 08:13 PM
Quadcammer
Quadcammer's Avatar
Received 1,372 Likes on 794 Posts
vern good sir, this has been discussed nearly one billion times.
a simple search will reveal all.
the short:
simple to replace, 3 10mm bolts, part costs about $45
Old 10-15-2013, 08:24 PM
vern1
vern1's Avatar
Quad good sir if i knew what to search for then i would have definitely done so. Just no idea what to look under. Pls fill me in and i will do so and thanks for the direction
Old 10-15-2013, 08:30 PM
NYC993
NYC993's Avatar
hot air socket - 964 211 323 03?
Old 10-15-2013, 08:40 PM
vern1
vern1's Avatar
Thanks!
Old 10-15-2013, 08:45 PM
P-daddy
P-daddy's Avatar
Here ya go, good gentlemen...
http://www.suncoastparts.com/product...993maintenance
Old 10-15-2013, 10:17 PM
jg291446
jg291446's Avatar
It's the fan shroud. Easy to install. Careful when buyin since 1995 993 needs the 964 part.
Old 10-15-2013, 10:22 PM
vern1
vern1's Avatar
Thanks all. Will grab the 993 part (i have a 96) and install
Appreciate it!
Old 10-15-2013, 10:39 PM
Mark Harris
Mark Harris's Avatar
Originally Posted by P-daddy
Sunset usually always beats Suncoast. Don't confuse your suns. I paid $32.83 for that cover less than a month ago.
Date: Mon, Sep 23, 2013 at 12:50 PM
Subject: RE: part
To: Mark Harris
Hi Mark
Fan $408.40 9641060153
Cover $32.83 99310640300
Sensor $86.66 99310603500
Quote #121157
Plus shipping to you
We have all in stock at this time
Thank you!
Bob McCarthy
Sunset Porsche Parts
Toll Free: 800.346.0182
Direct: 503.726.2257
BobMcCarthy@sunsetimports.com
Old 10-15-2013, 11:38 PM
Ed Hughes
Ed Hughes's Avatar
An engine rebuild is a DIY project. This is much simpler.
Old 10-15-2013, 11:54 PM
cgfen
cgfen's Avatar
DIY?
only if you can;
  • order the part
  • receive the part
  • remove the defective part,
  • 8mm socket
  • 2" extension
  • ratchet
  • Install the new part
  • align the components
  • drink beer afterwards
  • I suspect it is well within your capabilities
    have fun and good luck
    Old 10-16-2013, 01:54 AM
    element
    element's Avatar
    figuring out the Drive Block logic is a harder DIY :P
    phil.
    Old 10-16-2013, 02:23 AM
    IainM
    IainM's Avatar
    Seriously, I thought someone had vandalized my car when I saw that on mine. I looked up the part using the Porsche parts manual - you should get the one for your car:
    https://rennlist.com/forums/993-foru...-for-free.html
    Then I did a search here on the part name and discovered it's a common failure but not expensive or time consuming.
    I taped mine up with electrical tape for fear or impacting cooling airflow until the new part arrived.
    Old 10-16-2013, 02:28 AM
    IainM
    IainM's Avatar
    Anyone know why they blow out? Is it sudden shut off of air flow or sudden increase?
    Quick Reply: What is this and is it a DIY?
