HID Headlight up grade
If you use the tore kit, worst case you could convert back to stock on the spot. I keep my old bulbs in plastic just in case. No problems yet. MY DDM kit was actually fine as well. Turned out to be a loose wire once I pulled it apart to replace the set with the Torekit.. Crimped wire just fell out where I converted it to the bullet connector.
Me too - EFX was the brand I think, still work fine on my DD.
They work far better than the stock setup which worked about as well as two flashlights taped to the fenders...
I liked these so much, I purchased a set for the 'Busa as well - No issues there either.
I had a ballast go bad, and DDM was nice enough to replace it, even though it was out of warranty. I also installed the recommended relay that supplies voltage to the ballasts directly from the battery and have had no issues since.
contact Tore, he will take care of you, he is great to work with.
I've had a kit from Gert in my car for a few years and many nighttime miles, no problem. But as others have said, contact Tore... I wouldn't hesitate to use his kit either.
Turns out it was not the bulb. It was the component between the bulb and the ballast. I contacted Tores and he sent me a replacement next day no charge.
