993 Forum 1995-1998
Rubber bit
Old 03-17-2014, 09:16 PM
jerbroo
jerbroo's Avatar
Default Rubber bit
Hey guys,
I didn't see this rubber (or plastic) bit in the PET. Does anyone know the part number?
Tih,
Jeremy
Old 03-17-2014, 10:40 PM
jg291446
jg291446's Avatar
Auto atlanta : 15$
Ebay : 23$ with shipping
Pelican parts : 14$
How easy is it to replace?
Old 03-17-2014, 11:10 PM
jerbroo
jerbroo's Avatar
Awesome. Thanks bud. Looks pretty easy... I think the trick will be not to chip the paint. Lube... when in doubt, lube... And maybe some heat. Where'd you find the part number?
Old 03-17-2014, 11:58 PM
jg291446
jg291446's Avatar
I did a Google search with "993 trunk seal" and realised it was a weatherstrip.
I was curious to see how easy it was to replace since I need to replace some of them too, but mainly the one between the light and bumper, which may be harder to do.
Old 03-18-2014, 12:36 AM
TheBen
TheBen's Avatar
I just bought the body seals too
Old 03-18-2014, 12:49 AM
NP993
NP993's Avatar
It's called a cowl to fender seal. There are fasteners under the back of the fender (inside the door jamb, accessible with the door open) that need to be loosened to R&R it.
Old 03-18-2014, 10:19 AM
jerbroo
jerbroo's Avatar
Gracias.
Old 04-17-2014, 08:20 PM
mpruden
mpruden's Avatar
Wanted to revive this before it got too stale.
Jerbroo - how'd the installation go? Easy? hard? any surprises?
Old 04-17-2014, 09:18 PM
Warehouse33.net
Former Vendor
Warehouse33.net's Avatar
I did this on a pre 1989 911 awhile back without removing the fenders. It took me a few hours to be careful not to chip the paint. I don't know if the 993 is the same, but I assume it would be close.
Have these available here if anybody is interested.
Use the RENNLIST code to get 10% off.
-Jason
Old 04-17-2014, 10:20 PM
MarkD
MarkD's Avatar
As NP993 said, there is more to this than a simple remove and replace
Fasteners in the fender/jamb need to be removed to replace this seal
The seal is captured by the fasteners
Hope that makes sense
Old 04-17-2014, 10:34 PM
MartinC2S
MartinC2S's Avatar
I gotta do this too. Adding this to my parts order next time I call Andrea.
Old 04-18-2014, 01:30 AM
BesideTheBox
BesideTheBox's Avatar
Default Did this a couple weeks ago
I had my windshield replaced and they found a bit of rust, so I had that taken care of and the seals needed to come out for the respray around the windshield.
This is not an easy task.
Perhaps with better lubricant, it would have been easier? I used detail spray.
There are 2 fender screws, accessible after opening up the door.
The rear fastener goes through the seal.
The seal goes over, not through, the front fastener.
Loosen the front fastener and remove the rear fastener.
Gently, but firmly pull the old seal up and out.
Clean out the dirt and grime.
My recommendation is to start the install in the frunk with the hood up to get the seal located correctly.
You can always trim at the back if it is long.
Let's say there are 3 sections from front to rear.
  • trunk / frunk section
  • straight section
  • curved section
Start by laying out the trunk section, but don't push it in too far. Once you know how the seal should line up with the straight section (after all the curves in the frunk section), pull out the frunk section and very gently force two screwdrivers with paint protection (I used duck tape) between the fender and body to open up the space for the seal. Be very careful, there are countless ways that this could go bad. And yes, you are on your own. While gently prying, push the seal into the crevice. Work backwards through the straight section, and then onto the curved section.
That's how it went for me. Maybe with better lube it would have slid right in there, but I doubt it. Mine was freaking tight.
I hope this helps...
Old 04-18-2014, 11:07 AM
mpruden
mpruden's Avatar
Much appreciated for the detail. This is on my list as well. I'm now a little frightened though! Will follow up with any additional lessons learned once I get to it.
Quick Reply: Rubber bit
