Electric Mirrors both sides dont work
I have a few electric gremlins that I want to get to the bottom of (possible all related?)
First is neither electric mirror works, its possible its just a fuse but unforutnately I dont have an owners manual - any suggestions
Other minor niggles are the passanger seat electric seats dont work and the odometer needs a good tap to kick in - unsure if these are releated
help/suggestions appreciated
If it's both mirrors, it's most likely a fuse/relay/switch. You'll have to get a manual or some resource to start checking those out. Use Google to search rennlist past posts.
With so little info it's hard to know about the other issues. Seat could be a fuse or an issue with the seat motors or drive shafts under seat. Odo can be rebuilt by different shops. Ones called Hollywood tach or somethimg similar to that name if you search around.
I agree with the above comment as both are involved this should be a quick diagnosis and fix.
Never had this issue but if both adjustments don't work and I am assuming each use a different motor the problem should be easy and low cost to fix like the mirror.
If tapping the speedometer or Odmeter makes it work I would do the odometer gears replacement DIY on my kitchen table and while you have it out check the connections on the back and look for any internal debris or other factors that may be hanging things up. Again an easy inexpensive DIY fix.
Andy :-)
Andy :-)
Re the seats, the power cord under the seat can break quite easily - as the pvc sheathing becomes old it becomes brittle. Its a chair out job so you will need hex key!
