993 Forum 1995-1998
Sponsored by: DashLynx
Pop up.
Old 11-18-2014, 10:19 AM
x50type
x50type's Avatar
Default Pop up.
Should the the rear deck lid pop up a little when released, like the frunk does?
Old 11-18-2014, 11:01 AM
Texas993
Texas993's Avatar
Depends on how strong your deck shocks are. I have seen some pop all the way up when you pull the lever. And some (like yours maybe?) that don't move at all.
Old 11-18-2014, 11:24 AM
Pags993
Pags993's Avatar
My shocks are 3 months old and the rear deck lid only comes about 1.5 inches
Old 11-18-2014, 11:27 AM
rlme36
rlme36's Avatar
Mine with Turbo S wing will flip pancakes
Old 11-18-2014, 11:32 AM
993Mpls
993Mpls's Avatar
Video, please!
Old 11-18-2014, 12:29 PM
x50type
x50type's Avatar
I've just installed heavy duty OE struts 911 512 331 02 'cause i have Aero Kit II rear wing.
The wings lifts up fine but it doesn't pop up when i release it.
rime36 - what struts are you using with the turbo wing?
Old 11-18-2014, 12:55 PM
uniquenamehere
uniquenamehere's Avatar
Mine pops all the way up, so much so that I need to put my hand out to catch it when I pull the release. Struts are under a couple years old.
Old 11-18-2014, 02:18 PM
996scott
996scott's Avatar
mine doesn't pop up at all. I don't know how old the struts are but it sounds like it may be a winter project for me.
Old 11-18-2014, 02:26 PM
pp000830
pp000830's Avatar
Received 1,455 Likes on 1,026 Posts
After replacing the shocks on the frunk & Engine bay several times due to short service life I have given up and have made a genuine Andy approved custom prop made from premium recycled Oak, previously was flooring. Works great never have had to service the shocks since!
Andy
Old 11-18-2014, 02:28 PM
x50type
x50type's Avatar
996scott
After the lid has fallen on your head a couple of times you'll know it's time to change struts!
Old 11-18-2014, 03:28 PM
rlme36
rlme36's Avatar
Got them from Pelican 911-512-331-02-M24, the part number on my order history
Old 11-18-2014, 06:38 PM
x50type
x50type's Avatar
Can only suppose the Turbo S wing is much lighter than the Aero kit II wing as we are using the same struts!
Old 11-18-2014, 08:43 PM
kjr914
kjr914's Avatar
Default SPECIAL OFFER: VIAGRA for your decklid...
Like many others here experience, the years had taken their toll... I tried some enhancements and even some new shock therapy, but my decklid still didn't have that same "pop" that it used to. Searching for answers, I took a long shot and changed the rubbers I had been using.....BINGO! Now with a simple pull, my decklid goes stiffly skywards, ready for action!
What I mean was, even after new shocks were installed, the rear lid wouldn't pop up. So I ordered 2 new rubber stops for the bottom edge of the deck lid:
999 703 132 40 "rubber buffer" in the KATALOG/PET, BUT this comes up in Pelican as a front hood part, so... 999-703-140-41-M136 was the Pelican number that I ordered and it was correct ($1.75/each for OEM).
Super simple to install, as the rubber bumper has a screw-like thread that twists into the rear deck. Likely, you can just adjust your existing ones to stick out a bit more rather than order new, so give that a shot first.
Old 11-18-2014, 11:19 PM
x50type
x50type's Avatar
OK - how far out are the rubbers for your dick lid to go stiffly skywards - as opposed to a little premature episode?
And do you have any impediment on the lid which could contribute to the ED?
Old 11-18-2014, 11:29 PM
kjr914
kjr914's Avatar
I just, umm, played with it until it worked properly....
No wing or anything to hold me down or contribute to the, um, disfunction.
The new shocks would lift the lid fine once started, but it was getting it started that was the issue, so the bumpers fixed that. Several years later now, all is working fine still. My prior hood shocks lasted about 5 years.
Quick Reply: Pop up.
