993 Forum 1995-1998
Sponsored by: DashLynx
993 RS Tribute - The Build - The Photo's
Old 05-17-2016, 12:41 PM
  #91
trophy
trophy's Avatar
After the initial Dyno runs it became apparent that the Bosch Injectors were just not up to task of fueling the Beast. So at the recommendation of my Tuner at RCTS, I purchased a set of Injector Dynamics ID1000 Injectors..
Stock 993 Injectors flow - 230 cc/min @ 43.5psi
Bosch Injectors flow - 310 cc/min at 43.5psi
ID1000 flow - 1015 cc/min at 43.5psi,
In our fuel systems the fuel pressure is 3.8bar or 55psi the flow rates then jumps to @ 55psi:
993 Stock - 260 cc/min
Bosch "Red Devils" - 348 cc/min
ID1000 - 1140 cc/min.
Of course when I first looked at the numbers i was thinking that these were overkill, and really they are. Using simple 'Steven Math" which is neither accurate or based in any fact, I thought, if stock injectors can support 300hp, then injectors that are 4.4 times bigger then the potential of these new injectors is somewhere around 1300 hp.... I think I will be good for fuel.
The other major benefit of these injectors was the control, they are a modern style multi point injector, their control is incredible. At idle the injectors are at less that 5 % duty cycle. They are so easy to control, my tuner put a set in a Stock 1.6 l Honda, adjusted the ecu for dwell and dead times and it idled and ran perfectly. (1 single injector can actually run the Honda engine no problems )
Injector Dynamics also provides all the Dwell and dead time information so ECU setup is a breeze...
The injectors come with caps suited for the vehicle they are going in. Mine are the Purple ones.... I asked If i could get them anodized red, but no chance
Of Course nothing is ever simple as plug and play. The Injector plugs on 993's are whats called EV-1 and the ID1000 are USCAR. There are adapter pig tails available, however this is just not the right way to do the job. So one by one I removed the pins from the wiring harness plugs.
Old plug removed
New USCAR wiring plugs and crimp tool.
New black USCAR plug with an old EV-1 Plug in the back ground. Not so easy to return to Stock
Old 05-18-2016, 11:06 AM
  #92
0396
0396's Avatar
You are one well informed and talented individual.
Please keep them pictures / updates coming - thank you.
Old 05-18-2016, 11:09 PM
  #93
FLYT993
FLYT993's Avatar
steven, this is waay beyond simple engine ****! BREATHTAKING!!
Old 05-19-2016, 02:23 AM
  #94
FormulaRX
FormulaRX's Avatar
Pure awesomeness on every level!!!
Old 05-21-2016, 11:04 PM
  #95
trophy
trophy's Avatar
Thanks for the kind words guys!!!!
gathering more photos for you all to enjoy..
Old 10-24-2016, 02:28 AM
  #96
doc_porsche
doc_porsche's Avatar
Hoping to get updated pics pls
Old 10-24-2016, 11:33 AM
  #97
trophy
trophy's Avatar
I have a bunch of photo's from my friend Doug who wrote the article, haven't been through all of them as yet... Have a few long flights in my near future will go through them as I fly
Old 12-10-2016, 02:10 PM
  #98
Rinty
Rinty's Avatar
Steven:
Any plans to take the car to Area 27?
Old 12-12-2016, 10:09 PM
  #99
JPS
JPS's Avatar
So for the OP or anyone else. Assuming one just dropped their car off at an engine builder, what's a build like this cost?
Old 12-13-2016, 01:03 PM
  #100
Paddy
Paddy's Avatar
You're probably looking at 50K for someone to build what's in Trophy's car.
10k for heads
16K for ECU, wiring, injection, test/tune
6K for headers and 997 GT3 muffler
3.8 P&C 7K plus labor to modify your case
GT3 crank, oil pump, rods, bearings are expensive
Old 12-13-2016, 03:05 PM
  #101
Enso
Enso's Avatar
Hey neighbour, what a great post and so inspirational
How do you like the ID1000 Injectors, big difference?
cheers
Glenn
Old 12-14-2016, 11:13 PM
  #102
trophy
trophy's Avatar
Originally Posted by Rinty
Steven:
You bet, I have a few friends that are members out there.. Next year for sure, should be fun!
10k for heads
Paddy has it about right overall, There is a tone of time in this build, especially in the blueprinting etc, probably 8 to 10 hours in just balancing the piston, rods, rings and wrist pins. Then similar in matching the bearings for the crank and big ends. IF you are paing $120 to $150 an hour it adds up fast...
The other expense that we always forget about is shipping of parts etc. I probably ended up spending $2k on shipping bits and pieces back and forth from machine shops etc...
THe GT3 Parts are especially expensive, I thankfully got a few deals, however the Crank and oil pump are over $3k, the rods at the time were over $700 each.. Even the silly rod bolts were expensive.
The little things also add up, solid rockers over $1k, Cams $1k, Extra machining $2k, Head Studs $750, gaskets, consumables $1k... it all adds up fast.
cheers
Glenn
HEy Neighbour... Any time you are in cow town look me up! Thanks, for the props, it was an incredible journey, i learned an incredible amount doing the build!!
Super impressed with the ID1000's, the low Duty Cycle control is just incredible, even down at below 5% they are perfect. I also know I will never be lean because the injectors won't keep up, huge peace of mind...My engine loves fuel at high load, high RPM and these puppies are fantastic.
Old 12-17-2016, 01:40 PM
  #103
993Porsche
993Porsche's Avatar
Default Anticipating The Follow-up Photos
Subscribed.
Old 05-17-2017, 11:23 AM
  #104
fizzledorf
fizzledorf's Avatar
Wow. So much envy at the talent and time and patience that went into this build. Personally - lacking in all 3 areas most of the time... what a beauty. This build is just awesome. Really cool stuff
Old 11-29-2018, 03:54 PM
  #105
Chris M.
Chris M.'s Avatar
Originally Posted by trophy
I also drilled and tapped an additional port so I could get vacuum for the GT3 exhaust valves.
Did I miss more about the valved exhaust somewhere in the thread or article? It operates like the "sport exhaust" on the newer 911s, ie valves open and close with a button?
Quick Reply: 993 RS Tribute - The Build - The Photo's
