Top End Rebuild on 95 993 in Minnesota
#46
Andy
#47
A couple of reasons prompted it. First, the shop that conducted the PPI a while back led me to believe the car needed this service and the second is oil leaking on my garage floor all the time. I figured that winter is the time to put the car down and get things fixed. It may turn out that no top end is necessary.
#48
I bet your fix is a lot simpler than a top end.
Andy
#49
#50
Massive leak down percentages
Well, the engine is coming apart. Cylinder leak down test:
1. 75%
2. 75%
3. 78%
4. 10%
5. 15%
6. 5%
On the bright side a thorough inspection of the whole car revealed a torn axle shaft boot and a bad windshield washer pump. These are scheduled to be fixed as well as the engine so when she comes home it will 100%.
1. 75%
2. 75%
3. 78%
4. 10%
5. 15%
6. 5%
#51
1. 75%
2. 75%
3. 78%
4. 10%
5. 15%
6. 5%
1. 75%
2. 75%
3. 78%
4. 10%
5. 15%
6. 5%
Do you have compression numbers?
#52
#54
Those numbers are so high they seem suspect. The car would barely idle or would the car would seem to have no power or really gross symptoms like massive oil consumption (burning oil) with a OBDC fault code present. Leak down tests seem to be a quagmire from a diagnostic standpoint. My view is to not use them to gauge as a primary reason for engine rebuilding unless some other gross operating problem is apparent.
Andy
Andy
#55
1. 75%
2. 75%
3. 78%
4. 10%
5. 15%
6. 5%
1. 75%
2. 75%
3. 78%
4. 10%
5. 15%
6. 5%
A key piece of the puzzle... I would ask.
This could be rings, exh valves, intake valves... it really is important to know
And will predict exactly what needs to be done
Otherwise this could be a rather expensive endeavor
#56
#57
This was about 300 miles ago. Video Link: http://i856.photobucket.com/albums/ab122/gandalfthegray_1/20140419_163142_zpsc8e45642.mp4 Made 237 at the wheels. Car runs great, just has some serious oil leaks and some staggering leakdown numbers.
#58
This does not sound like a top end issue. More likely than not it is about replacing the typical dried out gaskets.
Now why do so many shops push for a top end rebuild? I think we all know why.
#59
