993 Forum 1995-1998
Sponsored by: DashLynx
993 Won't decelerate
Old 03-14-2015, 04:25 PM
PNW911
PNW911's Avatar
Default 993 Won't decelerate
My 1995- 993 with tiptronic does not decelerate normally below 2500 when I lift the throttle- a recent occurrence. It just carries on with steady revs. Have searched forums with no success- and checked throttle return spring. Also cleaned MAF, PO replaced O2, TDC sensors, etc. Any leads appreciated- thanks!
Am otherwise loving it- metallic grey on red. My 6th Porsche- first ever auto (tip) trans- which is truly a blast to drive- love the paddle shifting and the bulletproof feel. (Still have arena red/ black 993tt for summertime...)
Old 03-14-2015, 06:13 PM
Steve Weiner-Rennsport Systems
RL Technical Advisor
Steve Weiner-Rennsport Systems's Avatar
Check the engine VERY thoroughly for vacuum leaks.
Old 03-14-2015, 06:56 PM
MarkD
MarkD's Avatar
And make sure floor mat isn't binding the base of the gas pedal
Old 03-14-2015, 10:58 PM
Eurotrio
Eurotrio's Avatar
DME. My car would do that some times, especially when cold outside. Changed DME, and no rev hang now.
Old 03-16-2015, 12:22 AM
PNW911
PNW911's Avatar
Thanks Men! DME relay is new, gas pedal unrestricted and new vacuum all hoses all look ok. Should there be a vacuum hose to the DME relay? Searched web and Streather book for pix with no success...
Quick Reply: 993 Won't decelerate
