Ignition module failure discovery
Originally Posted by motobri
Please learn my why? Is the heat sink the insulator? Where do you put the paste?
motobri (06-07-2021)
I think the terminology is messing people up. You don’t use dielectric grease for the heat sink. You use conductive paste. That is what helps the heat being produced by the module be transferred to the heat sink (the metal it is bolted to).
pp000830 (10-01-2023)
Yep, this is a common mistake. I made the same mistake recently until I knew better. I thought they were the same thing with different names but they are not.
2nd Gear
Cupcar I took a whole month to figure out this exact problem on my 1995 993 C2. Had only 6 firing on one side of the ignition coil changed that to a new one and still not much of a difference. When we changed the ignition control switch it was like the car was alive again. Start up was very smooth, no bogging in between gears and on load. Car sits at good revs when the car is stopped. I imagine like you said this must be happening to a lot of 993s where the module is shutting down one distributor. As you said it ran "fine" but not nearly as well as now with the fix.
I blew a belt on my distributor at some point, and didn't really know what was up with the car, except that it felt lumpy off throttle.. I tested the distributor and found a belt broken.. I sent it off to Rothsport for a rebuild. After it was reinstalled, the car drove incredible.. I must've been driving around with the broken belt long enough for me to get used to it.. As above, I inspect every so often and also add a drop of oil to the felt lubricant pad on top... I had an extra ignition control module, but I sold it on eBay last year..
Cupcar I took a whole month to figure out this exact problem on my 1995 993 C2. Had only 6 firing on one side of the ignition coil changed that to a new one and still not much of a difference. When we changed the ignition control switch it was like the car was alive again. Start up was very smooth, no bogging in between gears and on load. Car sits at good revs when the car is stopped. I imagine like you said this must be happening to a lot of 993s where the module is shutting down one distributor. As you said it ran "fine" but not nearly as well as now with the fix.Thanks
