Gauge face color change
Hello all, as I finish the final details of my tip/man conversion, I have 2 last items to address.
The PRND321 on the speedo and the steering wheel. This bought me to buy gauge faces, so I can keep the original speedo there and not alter mileage as would be done with a replacement.
Then I decided to try a color change ( Hey I loved the red gauges in my GT3) but this layout is different.
I am not sure that I love this. I have had them in 2 weeks, and I am not fully warmed up to it.
These faces come from FVD. They are very good quality, but a notch or so under factory Porsche . I don't feel disappointed in the quality. I am not sure of the overall effect though.
Ideas?
Thank you
Ideas?
Thank you
By the way, I realize I still need to address the steering wheel!!! I was thinking of repurposing the switches for up/down shift, but then decided now is a good time to get a nice custom covered wheel.
The cost of the gauge faces from FVD is near 350 dollars. They give 12 different faces to cover all possible years/models.
I considered keeping the fuel/oil and clock black, which looks ok too, but in the end decided to do all.
To do this job it takes about an hour and a half for each gauge. It is not hard, but it can be tricky. I had a hard time removing the needles/pointers on the fuel/oil gauge. For some reason, the needle would not release from the pin that it is pressed onto. I actually pulled the entire pin out of the stepper motor in the gauge. If done right, you can simply re-insert the pin and all is well ( I called the Cali speedo shop)
Anyway, any comments or ideas that will help me warm up to this look?
Thank you
Rich
Thank you
Rich
I think if you have other red items like red script on carpet or seat belts, it will help.
I don’t know what to think about the red gauges, I looked at the pictures a few minutes and can’t if I like or not. I honestly don’t like the black ones, but prefer white.
For your steering wheel, if you want to keep the same without the shifting buttons, go on Rennlist Facebook. There is a guy selling a really nice one for 175$.
i wanted to do something similar but only was planning to do the tach with a red face. but i cant find anyone who sells the colored faces separately. you have to buy all of them. maybe try just keeping the tach red.
I just ordered a custom, red faced, rotated, higher redline and custom text, will post the proof when I get it... and I orderd just the tach...
There is another thread about this somewhere....
"i wanted to do something similar but only was planning to do the tach with a red face. but i cant find anyone who sells the colored faces separately. you have to buy all of them. maybe try just keeping the tach red."
+1. Red is very sporty but is a little much when all the dials are done. Taking a page out of the Ferrari book, just the tach looks good but isn't over the top. I actually thought about red but chose silver for my tach and have never regretted it.
I currently have silver gauge faces (uncertain if aftermarket or OEM). I like them a lot as is, but I decided to order a red rotated tach face from Porsche Dials. I've got a red leather interior to play off of in terms of color scheme. I'll post pictures when I finally get the gauge face and install it.
Personally I'm much more a fan of one colorful dial face (the tach) rather than 5. That's a lot of red in your peripheral vision all the time!
Thank you all for your replies and opinions. I too am not sure. In my GT3 I really loved it. But I now realize what the difference is. The gauges in a 993 take up the entire cockpit area and it simply is too much. I think maybe I will do as said. Keep the red tach, buy a manual speedo face (if I can find one) or a manual speed ( which is what I was avoiding in the first place!!!!) and convert it back.
The good news is the tach is the hardest to remove, and I will not have to play with that.
I do wonder though, how many times can you do the can opener routine on a VDO gauge before the lip splits off? My guess is around the 3rd time trouble will begin.
I am going to do red seat belts soon ( as the original webbing is starting to get hard) I was able to find the proper strength red webbing in 5 rib.
I read somewhere that seat belts and air bags do have a service life. If I remember correctly, it was 10 years.
I pray each day that I never test that!!!!!
Thanks again for all the terrific input. I sat there stumped as I looked and really felt it was time to get other thoughts.
Back to work!!!
Back to work!!!
Rich - I'd consider adding the aluminum trim rings instead (and keep gauges faces OEM).
https://rennlist.com/forums/993-foru...m-rings-8.html
Keep one red for tech gauge and change rest to silver color. It looks nicer with Alu trim.
Next, steering wheel you should go with 3 spoke and silver emblem if you can find one in decent $$....
Nice job on conversion!
