Running HD/B6 + M033?
friends ,
are you running Bilstein B6 normal aka HD ( not xtra thread ) with ROW M033 ?
( let us forget US truck height , focus on ROW ) .
ROW Standard : Front 154mm , Rear 147mm
ROW HD/M033 : Front ???mm , Rear ???mm
ROW CarreraRS : Front 124mm , Rear 107mm
plz post your ride height you achieved .
Yes, just measured the left side of the car:
Front: 143mm Rear:125mm. It's just a bit below ROW Sport height of 144/127mm.
I could have lowered the fronts a bit more with the limited front threads, but choose not to. My goal was to hit ROW Sport exactly prior to corner balance.
thx much for measuring !
how did you settle with 144mm ? how much more low could front go safely ?
Ride height with MO33 is intended to be the same as ROW MO30 which is ROW Sport height so nominally 144/127mm as mpruden mentioned. Tolerance for these heights is +/- 10mm.
Not to mention, I want to believe that Porsche thought through the ride height problem when they decided on 144mm for the ROW M030 package. I have no reason to think I could do it better for a street car.
I don't think you can go much lower than a few mm on the front without getting the extra thread version, but never checked.
Not sure what to say. I measured from the factory spots on a level floor using a digital caliper. It is what it is. 143 / 125. Perhaps the camera adds height like it adds pounds???
