993 on the Nordschleife
Besides the RSR flares, the wing and the cage, the car was pretty much stock when I got it. Since then I've put in proper safety gear (belts, extinguisher, main switch etc.), Moton clubsport shocks, monoball upper mounts, RS uprights, RS tierod ends, RS sway bars, motorsport hubs with centerlock. Otherwise it's all stock.
I am running 305/30/18 in rear and 265/35/18 in front.
Car has papers for racing (I've done two races this summer in the Finnish Porsche sports cup series) and at the moment we are in process of getting german racing papers for it (wagenpass). Plan is to race it on the ring on 25.10.
Cool
Looks a bit more hardcore than mine.
Betting on the shifter is this one (or similar): http://www.shop.cae-racing.de/index.php?a=158&lang=eng
The shifter is indeed the CAE shifter. I love it! In fact I love it so much I bought one for my CUP car too...
https://vimeo.com/138435613
Haven't see that one, but I know there's a Norwegian blue/purple 993 C2 with full RS body, rollcage ++ there often, he have a garage there, so the car stays there all year.
p.s. Also have a Guard 40/60 LSD in the car which has helped considerably under braking.
Matt
Juha - thanks for sharing. Awesome video and drive. I was wondering if you can share a bit on how you have the suspension set up? At least from what I can see in the video your car looks pretty stable. I have a very similar setup to yours (the Motons and all the RS bits and ride height, etc.). I have been trying to deal with a very twitchy rear end and have been adjusting everything (sways, camber, damping, rebound and tire pressures) to try and get more bite. My car is just too tail happy for my taste (and blood pressure given a couple of close calls this summer). Can you share alignment, sway bar settings, Moton settings (damping/rebound) etc? Thanks!
Matt
Matt
The car is indeed very stable. Very confidence inspiring. I believe part of it is due to the widened track and the beefy tires (265/35/18 front 305/30/18 rear) but also the shocks play a big part in it.
I can ask for the alignment specs from the racing shop that did it (LMS racing) but they are not very aggressive. All except for the upper mounts are original carrera 2 rubber joints, including engine and transmission mounts etc....so I am not a believer of monoball everything anymore. Of course this depends on what track you drive on what tires. With slicks I'd have it all stiffer but with semis I think the stock rubber is just fine. Oh, the car has over 100k miles, still on original joints...
I also have a set of 235+265 Federal RSR tires on wheels with more aggressive offset. So the track is equally wide but there is just less rubber (and not so grippy compound). I did a couple of laps on the Nordschleife with those too and the car was equally good to drive, just less grip.
I don't know if it has any effect but the car was set at RS height with racing slicks on it. The front tires are about the same size as now but the rear slicks were much taller than the semislicks I have there now. Therefore with semis the car sits lower in the rear now. I didn't feel that the car would've been pushing but then again I only drove it on the Nordschleife with the semis and that track has very few slow/tight corners where you'd have the car pushing.
Hi Matt,
[QUOTE=Juha G;12590908]We had some fun past weekend at the Nürburgring. My 993 has been there a couple of weeks already but I haven't had a chance to go and drive it until this weekend.
Juha -
That's some smooth driving indeed.
Great skills behind the wheel, the car it's element doing what it was designed for.
Juha -
yeah, that`s the real description.
I usually do trackdays but will try touristenfahrten next year.
Where is your car stored at the NOS while you are not there?
My friend runs a race shop there so he's looking after my car. Actually prepping it for the 25.10. RCN race as we speak.
i`m going to move from munich to frankfurt and hope, living much closer to the NOS next year than the last 10 years :-)
Perhaps, we`ll see next year at the devils dinner...
