993 Forum 1995-1998
Sponsored by: DashLynx
Those of us who NEVER replace window switches?
Old 12-22-2015, 05:04 AM
Railmaster.
Railmaster.'s Avatar
Default Those of us who NEVER replace window switches?
I read time and time again about the weak 993 window switches but never experience any problems myself! Nor does my 993 mates! What causes the switches to fail? Are som drivers just not careful enough with them? Or is it related to he climate where the cars live? Here in Sweden the summer weather really isn't that hot! Could for example the california sun cause the switches to go soft and fail? They are just plastic inside! You guys who claim You change them four times a year, where do You live and do You park the car in the sun often?
Old 12-22-2015, 07:22 AM
AOW162435
Seared
AOW162435's Avatar
10 years, no issues with any electrical switches.
Andreas
Old 12-22-2015, 07:39 AM
P-daddy
P-daddy's Avatar
Never broken one in 6 years of 993 ownership.
Old 12-22-2015, 08:20 AM
Van Larson
Van Larson's Avatar
Default Switches
My theory is that it is "helpful" to make sure that the up/down exertion is " centered" on the switch protrusion vs. pushing on the side(s) near the hinges.
Old 12-22-2015, 09:24 AM
sand_man
sand_man's Avatar
I've owned my '95 C2 for almost 3 years now. It is daily driven. It usually is in a garage, but there are occasions when it sleeps outside (oh the humanity). In the Carolina weather, I use the windows almost every time I drive the car. I have never replaced the switches and have found no evidence in all of the receipts that I got from the other owners, that they replaced them either.
Today the switches will fail!
Old 12-22-2015, 09:50 AM
tom97c4s
tom97c4s's Avatar
15+ years with my 993, never has a switch fail
Old 12-22-2015, 10:30 AM
PRSWILL
PRSWILL's Avatar
Had one fail last year- there's a plastic clip around a pin that breaks and I think it's due to nudging the switch laterally or pushing too hard on them. I bought 3 extras on line - aftermarket switches for 10-15 bucks each- they are super easy to swap out. There's a fix on here for the old switch, as well that uses a nail and drilling a small hole through the switch body- i save the old one to try it sometime. My last Porsche never had issues with these either, but who knows.
Old 12-22-2015, 10:49 AM
myflat6
myflat6's Avatar
First year of ownership with zero electrical issues.
Old 12-22-2015, 11:12 AM
mpruden
mpruden's Avatar
My car has been in the hot CA sun its entire 135k mile life.
No window switches replaced in the 12+ years of maintenance records I have.
Old 12-22-2015, 11:15 AM
pp000830
pp000830's Avatar
Received 1,456 Likes on 1,027 Posts
The original installed OE Switches are very robust and can last 15 years or more
The plastic paddle pivot gasses out, becomes brittle and cracks off, I suspect at a higher rate in warm climates. Once replaced the dealer service or third party aftearket switches have a much shorter service life. This is why an original repaired swich for some seems to be a more reliable route to take vs replacement.
Andy
Old 12-22-2015, 11:44 AM
PRSWILL
PRSWILL's Avatar
^^ That might explain mine- car spent the majority of its life in Arizona and California.
Old 12-22-2015, 11:46 AM
Jeff96-993
Jeff96-993's Avatar
I'm the second owner of a '96, which I bought in 1998. So I've owned it almost 18 years. I have never had a broken window switch.
Old 12-22-2015, 11:53 AM
Mark in Baltimore
Mark in Baltimore's Avatar
Never had an issue with broken window switches.
Old 12-22-2015, 11:57 AM
TMc993
TMc993's Avatar
+1...I had the driver's side switch break within the first week of ownership nine plus years ago. Replaced it and have not had to replace another since. I am more careful with the 993 switches than other vehicles I have and I think that has helped.
When I purchased the replacement switch I bought a second just as a precaution. It's still in my frunk in the original box. I guess it's old enough to be classified as an NOS part by now.
Old 12-22-2015, 11:58 AM
richardew
R.I.P
richardew's Avatar
Mine are among the most used switches. I have only had to replace 2 of the 3. Still have one original. I've had issues with these in all 3 of my 911s (89, 95, 96).
Quick Reply: Those of us who NEVER replace window switches?
