993 Forum 1995-1998
Sponsored by: DashLynx
993 Rebuild & More
Old 04-15-2017, 04:00 PM
  #196
Enso
Enso's Avatar
here I go putting the pistons in
I had a piston rod clip installer from Porsche for my 964 engine but the clips on the 993 have a 90 degree turn on them so this bugger won't work, i tried modifying it but no luck
this has to be one of the most frustrating jobs for me, i think i said the same sentence when doing the 964
anyway i saw somewhere a hand driver for inserting rod clips, so i made one kind of similar its crud but it worked on the first, second or 3rd try. not bad for me
i took a Phillips screw driver and filed a notch on the end that would hold the clip from almost slipping and ripping your finger off
Here it is
its starting to look like a motor again!
Old 04-15-2017, 04:11 PM
  #197
Enso
Enso's Avatar
More motor shots
Cam housing tightened down then head bolts
toque down (4 times checked) plus the 90Degree turn
then cam housing removed and lactate 574, oil returns (Viton seals)
Then housing torqued
sorry the sequence is wacked
Old 04-15-2017, 08:05 PM
  #198
bcameron59
bcameron59's Avatar
Nice work, looks like you'll be back on the road by the time summer arrives in late July!
Those clips were a bugger, glad I bought a few spares because a couple of them launched, I presume, into low earth orbit, never to be seen again. Smart move to cover the case openings, I only figured that one out after a very close call, thankfully didn't have to fish around in the case with the magnet...
You've probably thought of this already, but if not, now would be a good time to replace the alternator brush / voltage regulator unit.
Old 04-17-2017, 11:33 AM
  #199
Enso
Enso's Avatar
Hey Brian
Just a few years back Carla and I were driving to Calgary in the 964 C4
About 10 K from Calgary on #7 all the lights started flickering in the dash (ALL of them)
I was thinking the wurst We were driving up the hill on 16th ave and it died
I finally figured out it was the alternator
Thanks for the reminder Brian, I think I'll be taking your advice
Cheers
Glenn
Old 04-24-2017, 10:26 PM
  #200
Rinty
Rinty's Avatar
Originally Posted by Enso
I went out to Milden a week ago to help put the doors and rear lid on...
A 993 in Milden. Who'd a thunk it?
Thanks for the updates, Glenn.
Old 04-25-2017, 12:12 AM
  #201
Enso
Enso's Avatar
Yes Rinty it's one for the Milden history books, there's 181 people and a great car painter
Old 09-27-2017, 11:07 AM
  #202
Enso
Enso's Avatar
Greetings sorry i haven't updated for a while, family and life always seems to get in the way of the important stuff
Ive come a long ways but because of the depth of the tear down and time needed Im not there yet
Here is some pics of the motor assembly
Glenn
Old 09-27-2017, 11:15 AM
  #203
Enso
Enso's Avatar
i decided to go with the FabSpeed Cat Bypass
I was sent to Right pipes, even tho the pipes are the same it makes the left FabSpeed face the other way with one of the nut holes facing out
not sure this is normal, no biggy
Old 09-27-2017, 11:25 AM
  #204
Enso
Enso's Avatar
while i was in there i decided to replace the alternator bushings and give the fan a paint job
yellow like my callipers
Old 09-27-2017, 11:30 AM
  #205
Bergo
Bergo's Avatar
Looking good Glenn, might be able to make it to the last cars and coffee of the year in the 993 at this rate! My 911 goes in to get a damage appraisal at the end of the week, might be 993 shopping if it doesn't go well.
Old 09-27-2017, 11:31 AM
  #206
Enso
Enso's Avatar
i needed to replace 2 spark cables so i order some Beru cable and ends to do the fix
motor mounts from Steve Weiner
Old 09-27-2017, 02:05 PM
  #207
bcameron59
bcameron59's Avatar
Looking good!
I especially like the yellow fan... i did the same thing during my rebuild a couple of years ago, theory being it's easier to see so is less of a safety hazard.
Did you paint or powder coat?
Old 09-28-2017, 07:34 AM
  #208
Cameltoe & Heel
Cameltoe & Heel's Avatar
More new parts to install..what a slope:big gulp:
New pilot bearing installed, i made a note to myself just in case i forget to check the depth lol
Could I ask what the details of the check you make against the crank?, I've installed a new pilot bearing in my flywheel and just sat it flush as it appeared when removed.
Any input appreciated
Trev
Old 09-28-2017, 12:27 PM
  #209
Enso
Enso's Avatar
Looking good!
Lol yes having lost a finger to a blade when i was a tot has brought that idea to the forefront
No powder coat this time, i just went with a can of motor spray paint
Old 09-28-2017, 12:31 PM
  #210
Enso
Enso's Avatar
Trev
i used a digital depth gauge and also started with the pilot a little high and slowly tapping it to flush with crank
you could use a form of paint too to test depth
good luck
Quick Reply: 993 Rebuild & More
