Dye job - the journey
#61
We may all call it dye but what we see in this thread is not a dye but a leather paint. Not that i matters, just saying!
And I must also say that the result looks really great!
#62
Thanks for the positive feedback,
I'll be back from my travels on Monday and will get back to finishing this project!
#63
I would not put the filler on. Leather is a natural product and you are just adding something that could break in the future. I did you seats with color plus 9 years ago and refreshed the bolsters 3 years ago. The refresh is easy because of the perfect color match.
#64
Back at it this week. I have full coverage on the uppers and two coats on one of the seats. The other seat has a few very deep creases and I am going to try filling just two of the deepest. I know there are some who advise against it but I trust Joanne at Colorplus and don't think it will make anything worse. We'll see!
Next step is to airbrush the uppers. Never used an airbrush before so I plan to spend some time practicing on the weekend before tackling the seats.
Here are the uppers ready for spraying. For those who have sprayed - do you recommend 20 psi or 30 psi?
#66
If the surface appears too matte afterward, don't worry too much. You can take a microfiber towel and sort of wipe down to and buff the surface after things have completely dried to lessen the matte appearance.
#67
Originally Posted by axl911
Don't know what pressure to use since I didn't use an airbrush, but what you're trying to do is to get a VERY thin coat to even out the texture. Basically like misting the paint/dye onto the seat. I held my sprayer at least 12 inches from the seat and let the paint mist around the area. At this point, you're not painting/dyeing anymore. You're just trying to create a uniform texture onto the leather. Those little mist droplets falling onto the seat surface evenly will do that. Not sure how to explain it better....
#69
That looks really good. You took your time and did it right.
#72
Thanks guys - assuming the new coating holds up over time I will be very satisfied.
My airbrush paint room didn't work out as well and it seemed from my last post. The culprit was the cheap airbrush I bought. In the end I couldn't really justify spending $350+ on a higher end airbrush + compressor so I tried a $150 item. It ran fine for about 7-8 min but then shut down and 2 hrs later was still re-generating.
I noticed that the refractory period was pretty long when I was practicing with it but I think it just plain gave out yesterday. I'm returning it to Amazon today.
I did get through most of the one upper and now have to decide if I just re-assemble without the airbrush, or if I try to find a local (Toronto) friendly who has a decent set-up I can borrow.
I was pretty skeptical of the airbrush as soon as it arrived and I read the feature copy on the side of the box. The paragraph section was the give-away....
#73
Nice work! Looks great.
#74
