993 Forum 1995-1998
Sponsored by: DashLynx
sudden STIFF stick shift???
Old 03-27-2016, 04:03 PM
jgeeeb
7th Gear
jgeeeb's Avatar
Default sudden STIFF stick shift???
I went for a romp in Topanga yesterday and as soon as I reached the PCH to head home, my stick shift felt like it siezed up. The clutch felt normal. It still engaged and released perfectly, but getting in and out of gear suddenly felt like a gorilla was fighting against me. The only thing I can think of is that one or more of the cables siezed or lost lubrication or something. I drove it home fine but like I said, getting it in and out of gear took a good bit of pushing and pulling. Anyone experience this? Thanks!!!
Old 03-27-2016, 04:52 PM
71-3.0-911's Avatar
Immediate thought is to check your shift bushings and lower guide cups. Any grinding when going into gear or like your clutch pedal feel different?
Old 03-27-2016, 04:56 PM
Leander
Leander's Avatar
Engine (motor) mounts, perhaps.
Old 03-27-2016, 05:03 PM
wtdoom
wtdoom's Avatar
Going for a romp and then getting a stiffy has an entirely different meaning in the uk ...
jgeeeb
7th Gear
jgeeeb's Avatar
Nope. No grinding.
Old 03-27-2016, 05:05 PM
jgeeeb
7th Gear
jgeeeb's Avatar
This is what my brother posed as a possibility too. I never hit anything to cause any sudden shift. But I supposed it's possible.
Old 03-27-2016, 05:10 PM
NC TRACKRAT
NC TRACKRAT's Avatar
If your tailpipe tips are lower than normal, that's usually a sign of failing motor mounts.
Old 03-27-2016, 05:11 PM
u7t2p7
u7t2p7's Avatar
Consult RLer Goofballdeluxe on this; he doesn't contribute much technically here but I have a notion this is right in his wheelhouse.
Old 03-27-2016, 05:16 PM
TTKan
TTKan's Avatar
Have you checked Viagra in the fuel! Good luck with the repair!
Old 03-27-2016, 05:18 PM
shiraz
shiraz's Avatar
Old 03-27-2016, 06:41 PM
Holytin
Holytin's Avatar
Old 03-27-2016, 07:25 PM
Leander
Leander's Avatar
deleted
Old 03-27-2016, 08:58 PM
nine9six
nine9six's Avatar
+ 1 on this thought...I think motor mounts, or trans mount bushing failure is more progressive in nature...But anything is possible when parts get to this age.
Check to see if there is black oil looking, but not oily fluid leaking from the back of the car. If so, failed motor mounts. If the motor mounts are original, they should be replaced anyway.
Old 03-27-2016, 10:16 PM
jgeeeb
7th Gear
jgeeeb's Avatar
No oil. And tailpipes are not lower or askew.
Old 03-27-2016, 11:51 PM
jskylarwilson
jskylarwilson's Avatar
Have you replaced or modified the shift rod at all?
Quick Reply: sudden STIFF stick shift???
