993 Forum 1995-1998
Model designation on 1996-1998 CS and C4S tach
Old 04-17-2016, 09:00 AM
cdturne
cdturne's Avatar
Default Model designation on 1996-1998 CS and C4S tach
I have recently seen a 96 Carrera 4S and a 98 Carrera S with no model designation in the lower portion of the tach face. Instead, only a large blank space there. Did these cars not have this designation or are these faces changed out? Thanks.
Old 04-17-2016, 09:11 AM
RonCT
Moderator
RonCT's Avatar
Some do, some don't and I know there's a formula but can't remember it.
I know first hand my 1997 C2S with factory aluminum dials did not come with the Carrera S designation.
Old 04-17-2016, 11:18 AM
cdturne
cdturne's Avatar
Thanks. The 98 I mentioned also had the white dials and I assumed they were not original.
The 96 has black dials w/o the designation. Anyone have a known original of black w/o?
Old 04-17-2016, 11:53 AM
six gun
six gun's Avatar
bet the ""s" tag is under the white dial.
Old 04-17-2016, 12:11 PM
cdturne
cdturne's Avatar
So do the white dials simply fit over the black, not replace them?
Old 04-17-2016, 12:27 PM
nathan1
nathan1's Avatar
Only the 97-98 C2S models got the "Carrera S" script only if they didn't order the aluminum/colored dials or the On board computer (OBC). Either of those options cancelled out the script.
The 4S never got the script from the factory.
The other possibility is people often change the gauge faces to something other than stock and would the loose the script. If you have a 2S with black dials, no OBC and no script it's been swapped. Pull the tach out and check to see if the date codes match all the other gauges.
Old 04-17-2016, 12:42 PM
cdturne
cdturne's Avatar
Great information, thanks!
Old 04-17-2016, 03:54 PM
RonCT
Moderator
RonCT's Avatar
No, factory original, option code:
X71 Aluminum Instrument Dials
Old 04-17-2016, 04:01 PM
97c2s993
97c2s993's Avatar
I have the On board computer on my C2S and it has the script...but it's a tip in case that had anything to do with it.
Old 04-17-2016, 04:26 PM
User 122821
User 122821's Avatar
Not true, OBC equipped C2S did have the script on the Tach.
Old 04-17-2016, 04:30 PM
Franklin229
Franklin229's Avatar
Correct-that's what I have on mine.
Old 04-17-2016, 05:52 PM
Shahrams
Shahrams's Avatar
I have the OBC tach with the S script in my manual 98 S.
Old 04-17-2016, 06:53 PM
David993S
David993S's Avatar
My '97 has the "Carrera S" script at the bottom of the Tach, and I don't have the aluminum face.
Old 04-17-2016, 06:56 PM
PRSWILL
PRSWILL's Avatar
I don't have the script either - no biggie she's got the hips and big reds- 👍
Old 04-17-2016, 07:13 PM
six gun
six gun's Avatar
Since all C 2S cars were manufactured in 1997, how would you explain people ordering a 1998 car with white gauges for cars that were already built.
Quick Reply: Model designation on 1996-1998 CS and C4S tach
