993 Forum 1995-1998
Sponsored by: DashLynx
Plastic Engine Cooling Fan
Old 05-20-2016, 02:40 AM
  #61
Mike J
Mike J's Avatar
Any idea of the price point you guys are aiming for?
As a point of reference, a new Turbo fan from Sunset is $330.
Cheers,
Mike
Old 05-20-2016, 01:28 PM
  #62
Steve Weiner-Rennsport Systems
RL Technical Advisor
Steve Weiner-Rennsport Systems's Avatar
Cheers,
Mike
Not yet. These are not inexpensive to make so I think will be well beyond that price point. Considering durability & longevity (not to mention performance improvements), this will be a better long-term alternative.
Remember, a 993TT fan will not work in the 993 NA fan housing; you need the housing as well to do that.
Old 05-20-2016, 07:04 PM
  #63
OverBoosted28
OverBoosted28's Avatar
DELETED: Asked & answered
Old 05-21-2016, 02:57 AM
  #64
Mike J
Mike J's Avatar
I thought the fans were the same diameter between the NA and Turbo's and were interchangeable, and the difference in the shrouds were just because the Turbo needs the mounting spots for the IC. I did not know you cannot interchange the fans. Never compared them side by side, so good to know ...
Old 05-21-2016, 06:28 AM
  #65
ppashley
ppashley's Avatar
Subscribed.
Old 05-21-2016, 11:38 AM
  #66
Seamless
Seamless's Avatar
Yes the turbo fans are significantly smaller in diameter.
Old 05-22-2016, 11:07 AM
  #67
Coleman
Coleman's Avatar
Subscribed..
Old 05-22-2016, 05:28 PM
  #68
Ed Hughes
Ed Hughes's Avatar
Well, what was a boring wet Sunday afternoon, just got interesting!
Old 07-22-2016, 02:04 PM
  #69
ppashley
ppashley's Avatar
Any update on this interesting project... Steve?
Old 07-23-2016, 05:31 PM
  #70
pp000830
pp000830's Avatar
Received 1,455 Likes on 1,026 Posts
I seem to recall the fans on Vintage Porsche racecars were plastic. I suspect the metal fan has to do with service life as a metal fan can last the life of the car and in racing it need only last the life of the race. I too have heard about fatigue failures of the fan. I suspect the root cause of these failures has more to do with fan contact to the housing due to a misalignment or a failing bearing. Manufacturers go to great lengths to test performance and service life of components. I am sure if the engineers could get long life out of plastic it would have been implemented as a quality/cost out project long before the 993. The fact that the fan is made of magnesium not zinc pot metal or other lower cost heavier metal casting suggests that Porsche engineers focused on this part quite a bit to keep the weight down.
Old 07-23-2016, 06:45 PM
  #71
Ed Hughes
Ed Hughes's Avatar
I'm pretty sure Porsche wasn't worried about fans last 20+ years.
Old 07-23-2016, 08:53 PM
  #72
Actually, they are GRP and its pretty durable. I've had the original fans on the 907, 908, 917 and 935 cars hold up very well and I've not required replacements since I started in 1974.
Its simply FAR FAR more expensive to manufacture than a pressure casting.
  #73
Yep, but they sure did.
Old 07-24-2016, 11:20 AM
  #74
KMASS993
KMASS993's Avatar
Maybe you should consider using stainless magnesium... Cutting edge!
Old 07-24-2016, 11:59 AM
  #75
pp000830
pp000830's Avatar
Default Junk Science????
Uses three HP?? Seeing that the fan is spun up to speed when the car is running the use of HP is related to the pumping action of the fan not the acceleration of its mass to operating speed. Maybe we could gain three horsepower simply by removing the fan entirely? Then again the air intake tract would probably heat the air the engine uses quite a bit reducing combustion efficiency and output by a lot more than three horsepower! Then again 3 HP is just a guess in the first place according to the OP.
Quick Reply: Plastic Engine Cooling Fan
