993 Forum 1995-1998
Sponsored by: DashLynx
Octane gas question
Old 09-21-2016, 01:56 PM
Ron
Ron's Avatar
Default Octane gas question
I used to have a few service stations that sold pure gasoline 93 octane, now those stations only have pure gas with 90 octane. They all sell 93 octane with ethanol.
Why no more 93 pure gas I have not been able to determine.
So question is which better choice at this time? 90 octane pure gas or 93 octane with ethanol?
Old 09-21-2016, 01:59 PM
Steve Weiner-Rennsport Systems
RL Technical Advisor
Steve Weiner-Rennsport Systems's Avatar
Use 93 with ethanol and add Marine Stabil for protection.
Old 09-21-2016, 07:25 PM
GBX
GBX's Avatar
Interesting.....how frequently??
Old 09-21-2016, 07:37 PM
Bill Verburg
Bill Verburg's Avatar
The only place I've seen 93 or better pure gas is at racetrack pumps
91 pure gas has been generally available around here for a few years
From what I can see 91 pure will run as well as 93 w/ 10% ethanol. The reason is that the energy content of the ethanol blend is lower so a larger volume of fuel will be needed, this causes the injectors to run closer to the ragged edge of their duty cycle where they are less efficient. This is for track use, in street use it's probably not much different.
I've been using Startron(preferred) or Stabile for longer term storage when an ethanol blend is in the car. The reason for using a stabilizer is that gas and ethanol will separate from each other over time w/ temperature fluctuations( spring and fall are the worst), The stabilizer alleviates the issue.
Old 09-21-2016, 08:59 PM
cdturne
cdturne's Avatar
How much StaBil Marine to use to counteract the ethanol? I've been using 1oz/10 gal. Is that enough?
Also, I usually pour it in after fill up so it doesn't get "mixed" in till later. Is this an issue?
Old 09-21-2016, 09:15 PM
Cactus
Noodle Jr.
Cactus's Avatar
Why wouldn't you put it in first so it gets mixed right away?
Old 09-21-2016, 09:32 PM
NC TRACKRAT
NC TRACKRAT's Avatar
This may be of use: http://www.pure-gas.org/extensions/map.html
Old 09-21-2016, 10:57 PM
nine9six
nine9six's Avatar
Thats what I do...Marine Stabil in first, then fuel to mix it thuroughly in the fuel tank.
Old 09-22-2016, 02:57 AM
djantlive
djantlive's Avatar
How does stabil improve the gas?
Old 09-22-2016, 09:09 AM
pp000830
pp000830's Avatar
Received 1,455 Likes on 1,026 Posts
I use whatever 93/92 pump gas that is available. Once a year I put two consecutive tank fulls with Techron added. Seems the issue with alcohol blended gas for a daily driver is overblown. Now for cars stored over winter or that sit for weeks at a time treating the fuel may always be a good idea.
Old 09-22-2016, 09:44 AM
EMBPilot
EMBPilot's Avatar
you do this regularly, every tank? i had no idea this was commonly used in our cars
Old 09-22-2016, 11:06 AM
HPNer
HPNer's Avatar
A question on octane rating from a guy called Ron . . .
You couldn't make it up . . .!
Old 09-22-2016, 11:23 AM
sdm100
sdm100's Avatar
Stabil makes an ethanol treatment so you don't need the marine brand
http://shop.advanceautoparts.com/p/s...FYEYgQodZ9ULtA
Old 09-22-2016, 11:42 AM
fsa
fsa's Avatar
Default Stabil
Stabilizers like Stabil are critical to use in small gasoline engines, like lawnmowers. Ethanol gums up carbs and loves to help digest rubber.
HOW MUCH STA-BIL® ADDITIVE SHOULD I ADD TO FUEL?
For STA-BIL® Storage, use one ounce (30mL) to 2½ gallons (9.5L) of gasoline, gas/oil mixtures, or ethanol blends.
For STA-BIL 360° Performance, for storage and everyday ethanol treatment​ use one ounce (30mL) to 5 gallons (19 L) of gasoline, gas/oil mixtures, or ethanol blends.
For STA-BIL 360° Marine, for storage and everyday ethanol treatment​ use one ounce (30mL) to 10 gallons (38 L) of gasoline, gas/oil mixtures, or ethanol blends.
Old 09-22-2016, 12:22 PM
Yessir!
This is the correct way to use ANY fuel additive.
Quick Reply: Octane gas question
