993 Forum 1995-1998
Sponsored by: DashLynx
Cigarette lighter socket loose...
Old 01-01-2017, 03:00 PM
Zeus993
Zeus993's Avatar
Received 1,243 Likes on 573 Posts
Default Cigarette lighter socket loose...
Hey guys - Happy New Year 2017!
My first "993 Project" in the new year needs to be repairing my cigarette lighter socket so as my trickle charger doesn't fall out. It's simply loose.
Any ideas on how to tighten it up without replacing it?
Failing that here is my Suncoast replacement option: https://www.suncoastparts.com/produc...23070001C.html
TIA (Thanks in advance).
P.s. Once I've "tackled" this I doing the top end next!
Old 01-01-2017, 03:10 PM
nine9six
nine9six's Avatar
I found this with a search...
https://rennlist.com/forums/993-foru...-question.html
HTH
P.S. Once you've "tackled" this, you may want to do some extensive "searching" prior to doing the top end next!
Happy New Year!
Old 01-01-2017, 03:20 PM
OverBoosted28
OverBoosted28's Avatar
I know it may be convenient, but I don't get, why anyone wouldn't consider putting a pigtail on their battery. Direct charging, no fumbling with older lighter socket, and its a cleaner way. :-)
Old 01-01-2017, 03:30 PM
Zeus993
Zeus993's Avatar
HTH
Happy New Year!
Thank you! Some good ideas there that I will explore.
I totally agree. I just haven't got that far but that is a solid idea. The device I am using is not per say a charger but the Porsche Battery Maintainer.
Question - can you hard wire in the Battery Maintainer Claps for easy hook-up?
http://www.suncoastparts.com/product/00004320255.html
Old 01-01-2017, 05:57 PM
pp000830
pp000830's Avatar
Received 1,451 Likes on 1,022 Posts
The reason it is loose is it is a different size from modern sockets. Some offer a sleeve that slides over your charger's plug and takes up the play in the socket, this can also be made as a DIY project. Others simply put rubber bands or a couple o-rings over the plug as a spacer. Others do nothing. If you change the socket your dash will now not accept the OE lighter your car came with.
Sometimes knowing what not to fix is a daunting conclusion.
Andy
Old 01-01-2017, 06:07 PM
pp000830
pp000830's Avatar
http://forums.pelicanparts.com/off-t...er-socket.html
OverBoosted28
Just get a pigtail like this, directly mount to battery, and done!Name:  IMG_9746.JPG
Old 01-01-2017, 06:18 PM
pp000830
pp000830's Avatar
Just get a pigtail like this, directly mount to battery, and done!Attachment 1121678
Nice!
Old 01-01-2017, 06:47 PM
Zeus993
Zeus993's Avatar
Andy
Tx Andy. This makes sense. I'll check w BMW.
Perect. Then to get the attachment plug for the tender?
Old 01-01-2017, 08:37 PM
OverBoosted28
That was a "Deltran Battery Tender" (which I have had good luck with), but whatever charger/maintainer you buy, should have the pigtail, and clamps included.
Old 01-01-2017, 08:50 PM
nine9six
nine9six's Avatar
I think the Deltran Battery Tender is a quality device.
I've had mine for over 15 yrs., and God only knows how many times I've yanked it off its perch and onto the cement.
The Battery Tender takes a licking and keeps on ticking, er ah, humming n charging.
Old 01-01-2017, 08:55 PM
BlackSnake99
BlackSnake99's Avatar
I've had good luck with CTEK chargers. Have a pigtail on all my fun vehicles and I just rotate a charger sround the garage.
Old 01-01-2017, 10:48 PM
Greg Bell
Greg Bell's Avatar
I had the same problem with a loose fitting which needed to be held in place whilst removing whatever was in there, say a navigation device.
It is a bitch to replace, you'll need to remove your radio and have the patience of a saint to get the new one in. The trick is getting it aligned properly to slide in so the tabs can lock and fit the power leads. It is usually the plastic tabs that break off causing to fitting to be loose. Good luck.
Old 01-01-2017, 11:49 PM
Zeus993
Zeus993's Avatar
Any particular model you can suggest? Tx.
Excellent. Model No.?
Perfect
I think it's now CLEAR the the pigtail bolted on the battery is without question the way to go!
Thanks everyone.
Cheers for 2017!
Old 01-01-2017, 11:53 PM
Zeus993
Zeus993's Avatar
This?
http://products.batterytender.com/Ch...derR-Plus.html
or this?
http://products.batterytender.com/Ch...fficiency.html
Quick Reply: Cigarette lighter socket loose...
